Exchanging info between VB-VLisp-VB
Message 1 of 21
I have many programs in Visual Lisp and I would like to add some VB to them. I need to read visual lisp lists in my VB program and I don't know how to do it.
Any help?
Replies (20)
Message 21 of 21
"Tony Tanzillo" wrote... > My objection to the kludge-o-rama approach that got me > started in this, is that it embraces the unsound practice > of directly exposing private member variables (or global > LISP variables) to another API. Regardless of whether you > are passing data between LISP and VBA, or not, you don't > do it by attempting to directly manipulate variables in one > environment from another. Instead, you define a formal > interface consisting of functions that can be called from > one environment, to manipulate data in the other. > Tony, Thank you for taking the time to share this. It is quite helpful, but I am having a hard time understanding how having a formal interface in lisp is any different than having an interface in VBA that utilizes the same VL.Application as yours..... I mean, what Frank put together is by no means any rocket science type code, but rather a compilation of some useful functions that help poor sods, like I once was, to make the transition from lisp to VB(A). And those functions don't look much different than what is in your code. I found the VLAX class to be both useful AND educational......I learned that I didn't want to be passing data back and forth, although I could if I needed to. I have long since stopped trying to do this, but the newcomers need something to help them along (otherwise they wouldn't of asked the question). I still haven't gotten to the VB part, as that route costs money that I can't justify spending for the mods I currently write. But that doesn't mean that I don't want to learn the proper way to do things, it's just that sometimes we need a crutch to get past the falling down we do in the pursuit of learning. Thanks again, Jeff
