Excel to Acad Table
Excel to Acad Table
Message 1 of 8
Excel to Acad Table
I have read through many of the threads regarding transfer of information between Excel and Acad. Can you transfer Excel information right into cells of Acad's table? I would appreciate any help to code this.
Bill
Replies (7)
Message 2 of 8
I'll put this out here in hopes someone can improve it. You will need to
make adjustments to provide some information that
I get through calls to other functions, particularly in the function that
makes the table style.
This works, but it's eternally slow. Takes way to long to populate a table.
Near as I can tell, it's the .settext function where the value gets written
into the table cell that takes such a long time.
I put this out here in hope that maybe someone out there can improve it and
make it practical.
Please share any ideas
Public Function tl_Nz(v1 As Variant, v2 As Variant) As Variant
tl_Nz = v1
If IsNull(v1) Then
tl_Nz = v2
End Function
Public Sub tl_xls_to_table (ByVal filnam As String)
Dim dir As String
On Error GoTo Egress
Dim Excel As Object
Set Excel = GetObject(, "Excel.Application")
If Err.number <> 0 Then
Err.Clear
Set Excel = CreateObject("Excel.Application")
MsgBox "Could not start Excel.", vbExclamation
Exit Sub
Dim rownum As Integer
Dim excelbook As Workbook
Dim excelsheet As Worksheet
Dim cnt, cnt1 As Integer
On Error GoTo Handler
With Excel
Set excelbook = .Workbooks.Open(filnam)
excelbook.Activate
End With
Dim rowcnt, colcnt As Long
Dim xldat() As String
Set excelsheet = excelbook.ActiveSheet
With excelsheet
.Select
rowcnt = .UsedRange.Rows.Count
colcnt = .UsedRange.Columns.Count
ReDim xldat(1 To rowcnt, 1 To colcnt)
For rownum = 1 To rowcnt
For cnt1 = 1 To colcnt
xldat(rownum, cnt1) = tl_Nz(.Cells(rownum, cnt1), "")
Next cnt1
Next rownum
End With
cnt = 0
excelbook.Close
Set excelbook = Nothing
Excel.Quit
Set Excel = Nothing
Debug.Print "Finished reading xl at " & Now
Dim MyModelSpace As IAcadModelSpace2
Set MyModelSpace = ActiveDocument.ModelSpace
Dim pt(2) As Double
pt(0) = 0: pt(1) = 0: pt(2) = 0
Dim MyTable As AcadTable
tl_make_tablestyle
Set MyTable = MyModelSpace.AddTable(pt, rowcnt, colcnt, 12, 120)
ZoomExtents
Debug.Print "Starting table population at " & Now
With MyTable
If Not IsEmpty(xldat(rownum, cnt1)) Then
.SetText rownum - 1, cnt1 - 1, xldat(rownum, cnt1)
Next cnt1
Next rownum
End With
Debug.Print "Done at " & Now
GoTo Egress
Handler:
MsgBox Err.number & " " & Err.Description
Err.Clear
Resume Next
Egress:
If Not excelbook Is Nothing Then
excelbook.Save
excelbook.Close
If Not Excel Is Nothing Then
Excel.Quit
Set excelbook = Nothing: Set Excel = Nothing: Set excelsheet = Nothing
End Sub
'''this makes a table style. The scl value indicates the scale factor for
your drawing (i.e. 96 for 1/8"). The various stylenam variables
'''are the names of text styles to be used in the table.
Public Sub tl_make_tablestyle()
Dim scl As Double
Dim dict As AcadDictionary
Dim stylenam As String
Dim styledat As Variant
Dim tstyle As AcadTableStyle
scl = tl_getvar("tl_scale")
stylenam = "HCM_" & CStr(Fix(scl))
If scl = 0 Then
Exit Sub
Set dict = ActiveDocument.Dictionaries("acad_tablestyle")
On Error Resume Next
Set tstyle = dict(stylenam)
Set tstyle = dict.AddObject(stylenam, "acdbtablestyle")
Err.Clear
If Not tstyle Is Nothing Then
Dim colr As AcadAcCmColor
Set colr = New AcadAcCmColor
colr.ColorIndex = acWhite
Dim style1, style2, style3 As String
styledat = tl_do_make_textstyle("anntext")
style1 = styledat(0)
styledat = tl_do_make_textstyle("title_2")
style2 = styledat(0)
styledat = tl_do_make_textstyle("title_3")
style3 = styledat(0)
With tstyle
.Description = "HCM table - " & tl_scaletxt(scl, False) & "
scale"
.SetTextHeight 1, 0.09375 * scl
.SetTextHeight 4, 0.125 * scl
.SetTextHeight 2, 0.1875 * scl
.VertCellMargin = 0.0625 * scl
.HorzCellMargin = 0.0625 * scl
.SetTextStyle 1, style1
.SetTextStyle 2, style3
.SetTextStyle 4, style2
.SetAlignment 1, acBottomLeft
.SetGridColor 1, 2, colr
.SetGridColor 4, 1, colr
.SetGridColor 40, 7, colr
ActiveDocument.SetVariable "ctablestyle", .Name
End With
Exit Sub
Handler:
Err.Clear
Resume Next
End Sub
wrote in message news:5105042@discussion.autodesk.com...
Bill
Message 3 of 8
No need for code...
In Excel, copy the cells you want, then in AutoCAD select Past Special, then
select AutoCAD Entities. The result will be table object with the
information you copied from Excel.
Matt W
"I did absolutely nothing, and it was everything I thought it could be."
Bill
Message 4 of 8
See posts in autocad.customization.dotnet. (Excel to AutoCAD Table). I
have been having dialog about this very subject in this newsgroup. It
pretty much explains what to do. A word of advice from one who has gone
through the pains of the threads is to limit the table rows to 25 at a time
and have a table style set up with the formatting. The last advice I will
have for you is to use myTable.RegenerateTableSuppressed = True whenever you
do anything to the table. This will speed you up dramatically. If you
still get stuck give me a shout back and I will try to post some of my code.
It is pretty lengthy!!
Nate
"Matt W" wrote in message
news:5105394@discussion.autodesk.com...
No need for code...
Matt W
Bill
Message 5 of 8
Thanks, Matt.
This works, sort of, but the resulting table has cell widths and heights
that take a lot of manual adjusting (we were trying to copy a planting list
with about 40 rows). Good trick to know in a pinch, though.
No need for code...
Matt W
Bill
Message 6 of 8
Nate -
Many thanks. The RegenerateTableSuppressed was what I needed. Execution for
a 200-line table went from about 15 minutes to about two seconds.
Note: To use the RegenerateTableSuppressed, you need to dim the table as an
IAcadTable2 rather than AcadTable. Took me a while to figure that one out.
"Nate Hunter" wrote in message
news:5105415@discussion.autodesk.com...
Nate
No need for code...
Matt W
Bill
Message 7 of 8
glad to help.
Nate
"Tony Burba" wrote in message
news:5106226@discussion.autodesk.com...
Nate -
Nate
No need for code...
Matt W
Bill
Message 8 of 8
Thanks for all of the replies, unfortunately, I have run out of time. I lost my window of time that I could fiddle with this. I will be able to return to this in a few weeks. I have this thread ear marked so that I can return, I'll be asking questions then...
Thanks Again,
Bill
