excel range size
excel range size
Message 1 of 8
excel range size
hello all
how to detect the maximum used
range in a excel spreadsheet, or
the max column and the max row
thanks
mark
Replies (7)
Message 2 of 8
Use the .UsedRange property of Excel.
Joe
Message 3 of 8
I got this from Gary McMaster a while back. It works great.
Dim iMaxRow As Integer
Dim iMaxCol As Integer
Dim oXLUsed As Range
Set oXLUsed = oXLSheet.UsedRange 'The entire used area of the sheet
iMaxCol = oXLUsed.Columns(oXLUsed.Columns.Count).column 'Highest column number of the
"Used range"
iMaxRow = oXLUsed.Rows(oXLUsed.Rows.Count).Row 'Highest row number of the "Used
range"
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Mark" wrote in message
news:9CC5C29235AD79BE64DA43156C795873@in.WebX.maYIadrTaRb...
> hello all
> thanks
> mark
Message 4 of 8
thanks
but tis method is giving me about 100 more rows,
i am not able to figure out why
mark
"Kent Keller" wrote in message
news:02B877F5A2873848C9364359F041EF10@in.WebX.maYIadrTaRb...
number of the
> "Used range"
number of the "Used
> range"
> Kent
> > hello all
> > thanks
> > mark
Message 5 of 8
Is your print range too large?
R. Robert Bell, MCSE
www.AcadX.com
news:D9EA54E8FAD6D0ED6F58A513A2587F44@in.WebX.maYIadrTaRb...
| thanks
| mark
sheet
| number of the
| > "Used range"
| number of the "Used
| > range"
| > Kent
| > > hello all
| > > thanks
| > > mark
Message 6 of 8
I have found that if you delete rows by highlighting them and then using the delete Key
instead of going to the edit menu and using delete that it still thinks they are being
used at least in Excel 97. Could that possibly be the issue?
Kent
> thanks
> mark
Message 7 of 8
Excel doesn't reset its UsedRange until you close and re-open the file.
Until then there's extra rows if you deleted data, changed formatting, etc.
You can use the following from
http://www.microsoftexceltraining.com/VBA/ExcelRanges.htm. Check out the
website for related hints:
'Find the very last used cell in a Column:
Range("A65536").End(xlup).Select
It's like going to the bottom of the column and hitting CTRL-UP.
James
Message 8 of 8
thanks to all
i had to delete contents in the range
below my last row, then save,
and it works fine now
mark
"James Belshan" wrote in message
news:5F13B853F8FD5FCD33D70C6C81D2D755@in.WebX.maYIadrTaRb...
etc.
> James
