Excel Drawing in AutoCAD VBA code upgrade from 2012 Library Type to Current
ksflagg
Observer Observer
ksflagg
Observer
Observer
I have engineering design worksheet in excel.  I wrote Excel VBA code that converts and pushes the design data from Excel into AutoCAD as a completed drawing.
The worksheet was functional with Excel in 2012-16 and using the Auto 2012 Library Type, with AutoCAD 2012.
I am now running excel on office 365 and AutoCAD 2020.
I plan to upgrade the code to work with my current versions.
I am preemptively requesting any resources or advice on making the changes before tinkering.
Thank you!
grobnik
Hi @ksflagg shall be better if you share the code and perhaps a drawing could be better.
In some cases shall be enough to select updated reference libray in excel vba project.
ksflagg
Observer
Observer
Here is a sample code section that uses all required commands.
It pulls the x,y coordinates from a table in excel.
I use, acadDoc.SendCommand, acadDoc.Layers.Add(), acadPol, acadDoc.ModelSpace.AddLinghtWeightPolyline().
Curious if there are new ways of sending this type of input from Excel or can I just update the references and correct any syntax that might have updated.
'---Draw Lines----------
'----CREATE LAYER-------
Set acadL = acadDoc.Layers.Add("LINES")
acadDoc.SendCommand ("-layer" & vbCr & "set" & vbCr & "LINES" & vbCr & "color" & vbCr & "111" & vbCr & "" & vbCr & "" & vbCr)
'--Run a loop to collect line coordinates--
j = 0
For i = 1 To countX
LineCoordinates(j) = ActiveSheet.Cells(Ra - 1 + i, Ca + 1)
j = j + 1
x = ActiveSheet.Cells(Ra - 1 + i, Ca + 2) * s
LineCoordinates(j) = x + p
j = j + 1
Next i
'--Draw the polyline in model space--
Set acadPol = acadDoc.ModelSpace.AddLightWeightPolyline(LineCoordinates)
'--Leave the polyline open--
acadPol.Closed = False
acadPol.Update
grobnik
@ksflagg
Could you try with below code for changing layer color, supposing acadDoc referred to current drawing not to application,
The other command seems simple, so I guess you have to update reference project library,
Dim Lay As AcadLayer
    Set Lay = acadDoc.Layers("LINES")
    Lay.color = 111
