Excel Dialog Response
Message 1 of 10
(First posted in MDT5 group)
I am updating MDT5 global variables from an Excel workbook that is fed by
data from a second workbook. When I update the variables (in a VBA
routine), Excel returns a " . . . Do you want to update this workbook with
changes from the other workbook . . .? Yes or No." How do I issue the
needed affirmative response to Excel to keep the program running? Perhaps
this is a better question for the VBA group?
Thanks.
Charlie-
Replies (9)
Message 2 of 10
Hi Charlie,
If you are opening the workbook from VBA then you should check out the
UpdateLinks argument for the .open statement. Given below is an excerpt
from Excel VBA Help:
Syntax
expression.Open(FileName, UpdateLinks, ReadOnly, Format, Password,
WriteResPassword, IgnoreReadOnlyRecommended, Origin, Delimiter, Editable,
Notify, Converter, AddToMRU)
expression Required. An expression that returns a Workbooks or RecentFile
object.
FileName Required String. The file name of the workbook to be opened.
UpdateLinks Optional Variant. Specifies the way links in the file are
updated. If this argument is omitted, the user is prompted to specify how
links will be updated. Otherwise, this argument is one of the values listed
in the following table.
Value Meaning
0 Doesn't update any references
1 Updates external references but not remote references
2 Updates remote references but not external references
3 Updates both remote and external references
If Microsoft Excel is opening a file in the WKS, WK1, or WK3 format and the
UpdateLinks argument is 2, Microsoft Excel generates charts from the graphs
attached to the file. If the argument is 0, no charts are created.
Hope this helps.
David
Charlie Carr wrote in message
news:B22FA25B56B138192FB79A0F92C96BA6@in.WebX.maYIadrTaRb...
> Thanks.
> Charlie-
Message 3 of 10
David,
Thanks for the response. Actually, the workbook isbeing opened via :
mcadDoc.UpdateGlobalParameterLink
From a stand alone workbook, this works fine. However when data is called
to that workbook from a remote source, it returns the 'do you want to update
. . .' question. If both files are open, then I don't think the question is
asked. I could use this as a workaround, I s'pose, but I'd rather find a
way with a little more finess. Any other thoughts?
C-
"David Moroni" wrote in message
news:DB22309C4DB270425E91D0DB0364E6B5@in.WebX.maYIadrTaRb...
> Hi Charlie,
> Syntax
RecentFile
> object.
listed
> Value Meaning
the
graphs
> Hope this helps.
> David
by
with
Perhaps
> > Thanks.
> > Charlie-
Message 4 of 10
Charlie,
Sorry, I'm still pretty new to Autocad, so I'm not familiar with the
mcadDoc.UpdateGlobalParameterLink. I've run into the update links dialog in
other VB projects I've worked on, so I thought the UpdateLink parameter
might apply here too. Good luck with this problem.
David
news:2656A027977E8FE3644DEB17AF238A16@in.WebX.maYIadrTaRb...
> David,
update
is
> Thanks,
> C-
> > Hi Charlie,
the
> > Syntax
Editable,
> RecentFile
> > object.
how
> listed
> > Value Meaning
> the
> graphs
> > Hope this helps.
> > David
> by
> with
> Perhaps
> > > Thanks.
> > > Charlie-
Message 5 of 10
David,
I'm trying the workaround, and I.m stuck again (I'm very new to VBA, but
been with Autocad for a long time). I tried opening the XL file in the
background to try to prevent the "do you want to update " message from
coming, and it is still there. So I thought I'd try your UpdateLink
parameter, but I'm obviously not getting it right. I've tried a lot of
variations, but it is essentially:
Excel.Workbooks.Open ("filename.xls",3)
I'm missing something in the syntax. The error message I get varies with
what I put in there, but everything turns out to be wrong. Can you give me
a clue?
C-
news:1731025D98CE5309DB0140242DD30278@in.WebX.maYIadrTaRb...
> Charlie,
in
> David
> > David,
called
> update
question
> is
a
> > Thanks,
> > C-
> > > Hi Charlie,
> the
excerpt
> > > Syntax
> Editable,
> > RecentFile
> > > object.
opened.
are
> how
> > listed
> > > Value Meaning
and
> > the
> > graphs
> > > Hope this helps.
> > > David
fed
> > by
workbook
> > with
the
> > Perhaps
> > > > Thanks.
> > > > Charlie-
Message 6 of 10
Charlie,
Try the following to open the workbook
Dim xlApp as New Excel.Application
Dim xlWorkbook as Excel.Workbook
Set xlApp = CreateObject("Excel.Application")
Set xlWorkbook = xlApp.Workbooks.Open(FileName:="filename.xls",
UpdateLinks:=3)
David
Message 7 of 10
Thanks. I tried it, and I still get the dialog box asking me if I want to
update! The file doesn't actually open in an XL window . . . it must be in
the background, though, because when I try to open the file in XL after
running this, I get a share violation, asking if I want to open it read
only, or notify the other user (myself). Is there a way to completely open
it, then close it all down (including the XL window)?
C-
news:F97B56229DB70482F060F053BC9544EA@in.WebX.maYIadrTaRb...
> Charlie,
> Set xlWorkbook =
> UpdateLinks:=3)
> David
Message 8 of 10
Charlie, I'm thinking you might have some success with
Excel.Application.DisplayAlerts = False in the code for Excel. This should
disable the message alert. As far as open and shut down, see below.
Public Sub ExcelStart()
Dim xlApp As Excel.Application
Dim xlBook As Excel.Workbook
Dim xlSheet As Excel.Worksheet
On Error Resume Next
Set xlApp = GetObject(, "Excel.Application")
If Err Then
Err.Clear
If Err Then
MsgBox "Could not connect to Microsoft Excel", _
vbCritical + vbOKOnly, sDiaTitle
Err.Clear
Exit Sub
xlApp.DisplayAlerts = False
Set xlBook = xlApp.Workbooks.Add
Set xlSheet = xlApp.ActiveWorkbook.Sheets("Sheet1")
xlApp.Quit
Set xlApp = Nothing
Set xlBook = Nothing
Set xlSheet = Nothing
End Sub
"Charlie Carr" wrote in message
news:E18C80E728346708C9C09E1739DAEBED@in.WebX.maYIadrTaRb...
C-
> Charlie,
> Set xlWorkbook =
> UpdateLinks:=3)
> David
Message 9 of 10
Charlie,
You were right that the code opened the workbook in the background.
That is why you got a share violation when you tried to open the workbook
again. Kevin Terry has given you the right approach when it comes to
automating Office apps. Any time you declare an object, you should always
exit or close the object application and then set the object to nothing. I
should have included that in my last post.
David
Message 10 of 10
Thanks. Kevin.
I'll give this a try when I get the chance. I had a small window of
opportunity to work on this, and I've since been pulled into something else
. . . you know how it goes. Maybe next week?
Thanks, all, for your help.
Charlie-
"Kevin Terry" wrote in message
news:B713A8AE4A78CA0C96935DB6AAE543AF@in.WebX.maYIadrTaRb...
> If Err Then
> Err.Clear
> If Err Then
> Err.Clear
> Exit Sub
> End If
> End If
> xlApp.Quit
> Set xlApp = Nothing
> End Sub
in
open
> C-
> > Charlie,
> > Set xlWorkbook =
> > UpdateLinks:=3)
> > David
