Excel/Autocad Vba: switching between applications
Message 1 of 1
I am trying to write down a macro in excel with the following aim:
A. open a form with following options:
  1. choose the column where the data to be exported are present
  2. select the autocad file where to export (with browse button)
B. switch to autocad file, maximize Autocad window, zoom extent
C. let the user pick 2 points in order to identify the window where to place the data
D. Place a MText containing the exported data.
Here is the code that runs when you decide to export notes (I arranged it from different web sources, since I am not a programmer). The problem is that: -maximization of windows seems not to work; -when I have several open drawing it fails to make the selected drawing active.
Public Sub DrawNotes(Nome_File As String, Psz As Integer)
Dim acadDoc As AcadDocumentDim line As AcadLineDim StartPt(2) As Double
Dim EndPt(2) As Double
Dim InsertPnt1 As Variant, InsertPnt2 As Variant
Dim Note_Testo As AcadMTextDim Note_Stringa As String
Dim i As Integer, fl As Integer
Dim Num_Note As Integer
Dim Larg_Note As Double
Dim Alt_Note As Double
Dim Hgt As Integer
Dim NFile As String
On Error Resume Next
Set Graphics = GetObject(, "AutoCAD.Application")AppActivate "AutoCAD"AcadApplication.WindowState = acMax
NFile = Right(Nome_File, Len(Nome_File) - InStrRev(Nome_File,"\")) AcadApplication.Documents.Item(NFile).ActivateSet acadDoc = Graphics.ActiveDocument
Graphics.ZoomExtents
Note_Stringa = "Notes:"Num_Note = 1
For i = 1 To 50
    If Not Note(i, Psz) = "" Then        Num_Note = Num_Note + 1        Note_Stringa = Note_Stringa + vbCrLf + Note(i, Psz)
NextInsertPnt1 = acadDoc.Utility.GetPoint(, "Seleziona Punto in Alto Sx")InsertPnt2 = acadDoc.Utility.GetPoint(InsertPnt1, "Seleziona Punto in Basso Dx")Larg_Note = Abs(InsertPnt2(0) - InsertPnt1(0))Alt_Note = Abs(InsertPnt1(1) - InsertPnt2(1))Hgt = Application.WorksheetFunction.Round(Alt_Note / Num_Note, 0)
If acadDoc.ActiveSpace = acModelSpace Then
    Set Note_Testo = acadDoc.ModelSpace.AddMText(InsertPnt1, Larg_Note, Note_Stringa)
Else
    Set Note_Testo = acadDoc.PaperSpace.AddMText(InsertPnt1, Larg_Note, Note_Stringa)
End IfNote_Testo.LineSpacingDistance = Hgt
Note_Testo.Height = Application.WorksheetFunction.Round(Hgt / 3, 0)
On Error GoTo 0
End Sub
Any help will be appreciated! Thank you in advance
Replies (0)
