Error when open DWG TrueView in VBA
Hi All,
I have got a problem when I am trying to open dwg file by DWG TrueView in VBA. I always got error say : ActiveX component can't create object when it comes to
Set App = CreateObject("DWGVIEWR.Application")
Have I got something wrong or I am missing any reference?
Daniel
have you declared app as folowed?
dim app as object
try the following text:
dim app as object
App.Visible = True
check if "DWGVIEWR.Application" exists in your registry
Hi sw,
Thanks for your reply.
I did declare app. But How can I check "DWGVIEWR.Application" exists in my registry?Just search "DWGVIEWR.Application" in my registry? I searched but not there? How can I register it?
Cheers
Daniel
staubli
Observer
Observer
I have also same question
I have a program (visual basic 6.0)
from this program , I can open a DWG file in Autocad
Dim Acadapp As Object ' Autocad Library is not define to be able to use different version !
On Error Resume Next
' Set Acadapp = GetObject(, "AutoCAD.Application.16")
Set Acadapp = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then
    ' Set Acadapp = CreateObject(, "AutoCAD.Application")
    On Error GoTo 0
    Set Acadapp = CreateObject("AutoCAD.Application")
Acadapp.Documents.Open (Myfile)
Acadapp.Visible = True
Now I want to be able to open a file with DWG TrueView
(I run the program on a PC where no Autocad is setup , only DWG TrueView 2011)
I have make many test , but I do not succeed to select application DWGTrueView ?
Set Acadapp = GetObject(, "DWGVIEWR.Application.17")
Set Acadapp = GetObject(, "DWGTrueView.Application")
Set Acadapp = GetObject(, "DWG TrueView.Application")
Set Acadapp = GetObject(, "DWG TrueView 2011.Application")
all of them failed with error message "error 429 ActiveX can not create this componant"
=> is it possible to make a macro , which can open DWG file with TrueView ?
