Error type missmatch
Message 1 of 10
I took a code right from a book for programming AutoCAD via vba, an error is given as a type missmatch in the line highlighted , any ideas ??
dim nbp as integer
For nbp = 0 To Val(Type_rad_form.TextBox1.Text) Step nbp + 1
MsgBox "SVP, choisir le chemin correspondant pour la tuyauterie du radiateur, " & nbp + 1 & vbNewLine & "(Uilisez un polyline)"
Dim objent As AcadLWPolyline
Dim dblnew() As Double
Dim lnglastvertex As Long
Dim varpick1, varpick2, varwcs As Variant
Dim varpick As Variant
ThisDrawing.SetVariable "ORTHOMODE", 1
With ThisDrawing.Utility
varpick1 = .GetPoint(, "Point 1 :")
varpick2 = .GetPoint(, "Point 2 :")
varpick2(0) = varpick1(0)
ReDim dblnew(0 To 3)
dblnew(0) = varpick1(0): dblnew(1) = varpick1(1)
dblnew(2) = varpick2(0): dblnew(3) = varpick2(1)
''obent = .GetEntity(,varpick,
If ThisDrawing.ActiveSpace = acModelSpace Then
Set objent = ThisDrawing.ModelSpace.AddLightWeightPolyline(dblnew)
Else
Set objent = ThisDrawing.PaperSpace.AddLightWeightPolyline(dblnew)
objent.Update
''If objEnt Is Nothing Then Exit Sub
'' exit if not a lwpolyline
''/////So far everythinggoes well ////////"
'' copy last vertex of pline into pickpoint to begin loop
''/////////////////////////////////////////////////////////////////// the next line gives the error while double can be assigned to variant ????
varpick(0) = objent.Coordinates(UBound(objent.Coordinates) - 1)
varpick(1) = objent.Coordinates(UBound(objent.Coordinates))
varpick(2) = 0
'' append vertexes in a loop
Do
'' translate picked point to UCS for basepoint below
varwcs = .TranslateCoordinates(varpick, acWorld, acUCS, True)
'' get user point for new vertex, use last pick as basepoint
varpick = .GetPoint(varwcs, vbCr & "Pick another point : ")
'' exit loop if no point picked
If Err Then Exit Do
'' copy picked point X and Y into new 2d point
dblnew(0) = varpick(0): dblnew(1) = varpick(1)
'' get last vertex offset. it is one half the array size
lnglastvertex = (UBound(objent.Coordinates) + 1) / 2
'' add new vertex to pline at last offset
objent.AddVertex lnglastvertex, dblnew
Loop
End With
objent.Update
Replies (9)
Message 2 of 10
Man I wish they'd hurry up and get this forum
software fixed so I could actually read these posts.....
A few things.....
This:
isn't doing what you think it is (well, it IS in
THIS case ending up that way, but usually it won't). Dim'ing a number variables
like this does NOT set them all to be what the AS specifies in VBA. Each one
must have it's own AS or they will default to the Variant type.
Now for why your code fails....
When you Dim the varpick variable as a variant, the
code does not know you really wanted a Variant Array. Change that to Dim
varpick(2) as Variant and it should work ok
HTH
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
I
given as a type missmatch in the line highlighted , any ideas ?? dim nbp as
integer For nbp = 0 To Val(Type_rad_form.TextBox1.Text) Step nbp + 1 MsgBox
nbp + 1 & vbNewLine & "(Uilisez un polyline)" Dim objent As
AcadLWPolyline Dim dblnew() As Double Dim lnglastvertex As Long Dim varpick1,
varpick2, varwcs As Variant Dim varpick As Variant ThisDrawing.SetVariable
"ORTHOMODE", 1 With ThisDrawing.Utility varpick1 = .GetPoint(, "Point 1 :")
varpick2 = .GetPoint(, "Point 2 :") varpick2(0) = varpick1(0) ReDim dblnew(0
To 3) dblnew(0) = varpick1(0): dblnew(1) = varpick1(1) dblnew(2) =
varpick2(0): dblnew(3) = varpick2(1) ''obent = .GetEntity(,varpick, If
ThisDrawing.ActiveSpace = acModelSpace Then Set objent =
ThisDrawing.ModelSpace.AddLightWeightPolyline(dblnew) Else Set objent =
ThisDrawing.PaperSpace.AddLightWeightPolyline(dblnew) End If objent.Update
''If objEnt Is Nothing Then Exit Sub '' exit if not a lwpolyline ''/////So far
everythinggoes well ////////" '' copy last vertex of pline into pickpoint to
begin loop
varpick(0) = objent.Coordinates(UBound(objent.Coordinates) - 1) varpick(1) =
objent.Coordinates(UBound(objent.Coordinates)) varpick(2) = 0 '' append
vertexes in a loop Do '' translate picked point to UCS for basepoint below
varwcs = .TranslateCoordinates(varpick, acWorld, acUCS, True) '' get user
point for new vertex, use last pick as basepoint varpick = .GetPoint(varwcs,
vbCr & "Pick another point : ") '' exit loop if no point picked If
Err Then Exit Do '' copy picked point X and Y into new 2d point dblnew(0) =
varpick(0): dblnew(1) = varpick(1) '' get last vertex offset. it is one half
the array size lnglastvertex = (UBound(objent.Coordinates) + 1) / 2 '' add new
vertex to pline at last offset objent.AddVertex lnglastvertex, dblnew Loop End
With objent.Update
Message 3 of 10
Hi Jeff,
The latest news I have (from last week) is that they acknowledge there
is a problem and they are talking to their service supplier to see if
may be they can have a planning session which will see if they should
think about coming up with a plan to see if the plan will be feasible if
able to be implemented in the fullness of time.
I think it's time to start writing to Carl Bass again.
Laurie Comerford
ps - I'm sorry my gobble-de-gook is almost comprehensible. I struggle
to fit myself into their mindset. 😞
Jeff Mishler wrote:
> Man I wish they'd hurry up and get this forum software fixed so I could
> A few things.....
> This:
> isn't doing what you think it is (well, it IS in THIS case ending up
> that way, but usually it won't). Dim'ing a number variables like this
> does NOT set them all to be what the AS specifies in VBA. Each one must
> When you Dim the varpick variable as a variant, the code does not know
> you really wanted a Variant Array. Change that to Dim varpick(2) as
> HTH
> "Elie911" wrote in message news:6203160@discussion.autodesk.com...
> ideas ?? dim nbp as integer For nbp = 0 To
> Val(Type_rad_form.TextBox1.Text) Step nbp + 1 MsgBox "SVP, choisir
> & vbNewLine & "(Uilisez un polyline)" Dim objent As AcadLWPolyline
> ThisDrawing.SetVariable "ORTHOMODE", 1 With ThisDrawing.Utility
> varpick1 = .GetPoint(, "Point 1 :") varpick2 = .GetPoint(, "Point 2
> :") varpick2(0) = varpick1(0) ReDim dblnew(0 To 3) dblnew(0) =
> varpick1(0): dblnew(1) = varpick1(1) dblnew(2) = varpick2(0):
> objent = ThisDrawing.PaperSpace.AddLightWeightPolyline(dblnew) End
> If objent.Update ''If objEnt Is Nothing Then Exit Sub '' exit if not
> a lwpolyline ''/////So far everythinggoes well ////////" '' copy
> variant ????
> varpick(2) = 0 '' append vertexes in a loop Do '' translate picked
> point to UCS for basepoint below varwcs =
> .GetPoint(varwcs, vbCr & "Pick another point : ") '' exit loop if no
> point picked If Err Then Exit Do '' copy picked point X and Y into
> new 2d point dblnew(0) = varpick(0): dblnew(1) = varpick(1) '' get
> last vertex offset. it is one half the array size lnglastvertex =
> (UBound(objent.Coordinates) + 1) / 2 '' add new vertex to pline at
> last offset objent.AddVertex lnglastvertex, dblnew Loop End With
> objent.Update
Message 4 of 10
Hi Jeff,
Thank you for your reply.
I use varpick in the GetPoint method which don't accept an array.
I also tried it but as mensioned, the error occurs : Can't assign to array
Any ideas ??
Message 5 of 10
Hi Elie,
The only place in the code, as best I can decipher
it due to the line breaks being stripped out, is here:
    With
ThisDrawing.Utility
        varpick1 =
        varpick2
        ReDim
dblnew(0 To 3)
        dblnew(0) =
varpick1(1)
        dblnew(2) =
varpick2(1)
        ''obent =
Then
            Set
objent =
Else
which is in a commented section of code, until you
try to assign it here:
1)
        varpick(1) =
varpick(2) = 0
But since it has not yet been used as an array, it
is erroring on you.
dir=ltr>
Hi Jeff,
array.
assign to array
Any ideas ??
Message 6 of 10
Yeah, I was informed of roughly the same thing about a month ago.
Me thinks their "service supplier" needs to be fired.
"Laurie" wrote in message
news:6203631@discussion.autodesk.com...
> Hi Jeff,
> Regards,
> Laurie Comerford
Message 7 of 10
Please can someone help me .
I have been working on this for 3 days and no result.
I need to add a polyline to the modelspace like this : get 2 point from the user for the first vertex, then get point by point until he presses Esc.
This code is giving an error "Invalid procedure call or argument" on the line where I add the LightWeightPolyline .
The code is :
Dim nbp as integer
pt1 = .GetPoint(, "Premier point :")
pt2 = .GetPoint(pt1, "Second point :")
var(0) = CVar(pt1(0))
var(1) = CVar(pt1(1))
var(2) = CVar(pt2(0))
var(3) = CVar(pt2(1))
End With
''///////////////////////////////////////error/////////////////////////////////////////
Set objEnt = ThisDrawing.ModelSpace.AddLightWeightPolyline(var)
Else
Set objEnt = ThisDrawing.PaperSpace.AddLightWeightPolyline(var)
objEnt.Closed = True
objEnt.Update
ReDim varpick(2)
varpick(0) = objEnt.Coordinates(UBound(objEnt.Coordinates) - 1)
varpick(1) = objEnt.Coordinates(UBound(objEnt.Coordinates))
varpick(2) = 0
Do
varwcs = ThisDrawing.Utility.TranslateCoordinates(varpick, acWorld, acUCS, True)
varpick = ThisDrawing.Utility.GetPoint(varwcs, vbCr & "Pick another point <exit>: ")
If Err Then Exit Do
lnglastvertex = (UBound(objEnt.Coordinates) + 1) / 2
objEnt.AddVertex lnglastvertex, dblnew
Loop
objEnt.Update
Next
Message 8 of 10
Give this a try Elie. I reordered some of you code
and added some Dim's.
{code}
Option Explicit
Sub testme()
Dim nbp As Integer
Dim dblnew(1) As Double
Variant
For nbp = 0 To 2 Step 1
polyline)"
Dim pt1 As Variant
Dim pt2 As
Variant
Dim var(3) As Double
End With
Set objent = ThisDrawing.ModelSpace.AddLightWeightPolyline(var)
Else
Set objent = ThisDrawing.PaperSpace.AddLightWeightPolyline(var)
objent.Closed = True
objent.Update
Do
Dim lastPt(2) As Double
lastPt(0) = objent.Coordinates(UBound(objent.Coordinates) - 1)
lastPt(1) = objent.Coordinates(UBound(objent.Coordinates))
lastPt(2) = 0
varwcs = ThisDrawing.Utility.TranslateCoordinates(lastPt, acWorld, acUCS,
True)
On Error Resume Next
as basepoint
point <exit>: ")
If Err Then Exit Do
On Error GoTo 0
Loop
objent.Update
Next
End Sub
{/code}
dir=ltr>
Please
result.
presses Esc.
Message 9 of 10
Why convert Double to Variant and then assign it to
a variable of Double type?
var(2) =
CVar(pt2(0))
It should be as simple as
var(0) = pt1(0)
var(1) = pt1(1)
var(2) = pt2(0)
var(3)
= pt2(1)
Of course, it is assumed you correctly declared var
as an array of Double somewhere before these lines of code (you did not show the
declaration in your code), like this:
Dim var(0 to 3) As Double
It is very likely you declared it this
way:
Dim var(0 to 3) As Variant
If so, you would get that error for sure, because
the argument of "AddLightWeightPolyline()"
method expects an array of Double, not an array of Variant.
Please
result.
presses Esc.
The
code is :
Dim nbp as integer
Dim objent As
AcadLWPolyline
Long
Dim varpick As
Variant
1
1
polyline)"
point :")
var(1) =
CVar(pt1(1))
End With
Then
Set
objEnt =
Else
Set
End
If
objEnt.Update
loop
ReDim varpick(2)
varpick(0) =
varpick(1) =
varpick(2) =
0
Do
varwcs =
True)
basepoint
picked
If Err Then Exit Do
into new 2d point
varpick(1)
size
2
offset
Loop
objEnt.Update
Next
Message 10 of 10
Now I corrected as you mentioned and another error is appearing from the line :
"Invalid Argument point in TranslateCoordinates"
Looking on the varpick elements, everything seems to be normal .
Any ideas ???
Regards ...
