Error: Command line is busy
I work with AutoCAD R14.01 and Delphi 5.0.
Sometimes, in input operations, AutoCAD give me the following error:
Command line is busy.
After that I can't work with input in command line and I have to restart
AutoCAD.
Any one could help me ?
Kevin Corazza
SierraSoft Srl
Input operations from Delphi or AutoCAD?
Kevin Corazza wrote in message
news:826a11$mr616@adesknews2.autodesk.com...
> AutoCAD.
> Kevin Corazza
> SierraSoft Srl
Input operations via automation from Delphi.
It sounds like your app is not returning control to AutoCAD. The real expert
in AutoCAD & Delphi is Tony Tanzillo. His email address is
tony.tanzillo@worldnet.att.net
But be sure to do your homework; he doesn't appreciate frivilous use of his
time.
news:826cjt$7a1@adesknews2.autodesk.com...
Post some code showing what exactly you're doing.
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
