_Ending a VBA-program nicely...
serge
serge
I have an icon who's starting a VBA-program, behind the icon there is e.g. ^C^C^P(COMMAND "VBARUN" "MyVBAProg")... When I trigger somwhere in my VBA-program the END-statement, I get a 'Execution errornil'-message in the Command-line ... how can I avoid this ? ... Thanks ... SMD
DEVIDTS Serge, CAD Consultant
http://www.CADdICT.be
End will stop your program, yes, but right at that
point, if you have code in your .Terminate event, of your form to end cleanly,
then it's not executed.
So if you have a form close it first, otherwise I
think I would need some code examples.
I
SMD
SMD,
The problem is that when a lisp function ends it will always return nil. So to fix your problem, you should wrap you lisp in a defun
(defun c:myvbaprog ()
(vl-vbarun "MyVBAProg")
(princ)
Then in your icon use ^c^cmyvbaprog;
Kilo
Unload Me?
I
SMD
serge
Works 100%, thanks !
Also, it would be better to use the Exit Sub/Function
statement instead of just End.
I
SMD
