Editing Dimension Text using VBA
I want to write a macro that adds "(TYP.) to any dimension I click on.
I am new to VBA and would like a littl help. Thanks!
I have a similar one on what you need
See how it will work for you
Option Explicit
Public Sub SelectMulty()
'' based on Tony Tanzillo technic
'' request check "Break on Unhandled Errors" in General options
Dim varPt As Variant
Dim oEnt As AcadEntity
Dim dme As AcadDimension
Do
On Error Resume Next
ThisDrawing.Utility.GetEntity oEnt, varPt, "Select Dimension: "
If Err Then
Err.Clear
Exit Do
On Error GoTo 0
If Not oEnt Is Nothing Then
If oEnt.ObjectName Like "*Dim*" Then
Set dme = oEnt
dme.TextPrefix = "TYP."
dme.Update
Set oEnt = Nothing
Loop
On Error GoTo 0
End Sub
~'J'~
PERFECT!!
You're welcome
~'J'~
