Edit dimension in template drawing
Message 1 of 9
Hi..
I'm new and trying to do some automation on autocad with VBA.
I need to modify some of the dimensions (text only) in a standard template of outline drawing for different cases.
I tried to identify the dimensions which need modification by using handle.
But after that i have no idea how to change the text in it.
Hope can get some suggestion and help here.
Thanks.
Replies (8)
Message 2 of 9
Hallex
Here is a code that will you override the dimension text
Is there  what you need?
Option Explicit
Sub OverrideDimension()
Dim oEnt As AcadEntity
Dim oDim As AcadDimension
Dim oDimAl As AcadDimAligned
Dim oDimRot As AcadDimRotated
Dim oSset As AcadSelectionSet
Dim sizeStr As String
Dim dblStep As Double
Dim dblDim As Double
Dim iCount As Integer
Dim dimStr As String
Dim ftype(0) As Integer
Dim fdata(0) As Variant
Dim dimPrec As Integer
dimPrec = ThisDrawing.GetVariable("dimdec")
sizeStr = InputBox("Enter a size" & vbCr & _
"(50,100,150,200,250,300) :", "Parameter Input", "200.0")
dblStep = Val(Replace(sizeStr, ",", ".", 1, -1, vbTextCompare))
          With ThisDrawing.SelectionSets
               While .Count > 0
                    .Item(0).Delete
               Wend
               Set oSset = .Add("$Dim$")
          End With
      ftype(0) = 0: fdata(0) = "DIMENSION"
     oSset.SelectOnScreen ftype, fdata
     For Each oEnt In oSset
     If TypeOf oEnt Is AcadDimAligned Then
     Set oDimAl = oEnt
     dblDim = oDimAl.Measurement
     iCount = CInt(dblDim / dblStep)
     dimStr = CStr(Round(dblStep, dimPrec))
     oDimAl.TextOverride = dimStr
     ElseIf TypeOf oEnt Is AcadDimRotated Then
     Set oDimRot = oEnt
     dblDim = oDimRot.Measurement
     oDimRot.TextOverride = dimStr
     Next oEnt
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 9
Dear Hallex,
Thank you very much for your reply.
But i dont think it is something in my mind.
The senario is, i have a template drawing with the outline of let say a square box.
i dimension the length = A, width = B, height =C
Using VBA, i create a form to key in the value of A, B and C to override into three of the dimension.
The problem i facing is i cannot figure out how to override the dimension without manually select the dimension itself.
The actual case is the dimension need to be override is approximatte 50~60. So i cant afford to select one by one...
Message 4 of 9
Hallex
In this case create template with box  where dimensions are: 1x1x1
and add all three dimensions in there
then in the form you have to add new dimensions
and scale template using scale by X,Y and Z
and set dimension text size and arrowhead size to
your suit after, sorry, just a hint :)\
~'J'~
Message 5 of 9
Thanks Hallex for replying
The box is an example. As i mentioned in my previous post, the actual case i need to modify 50~60 dimensions.
My idea is, i dont change any thing on the title block and drawing itself.
Just wanted to change the text on the dimension.
Hope anyone out here can advise.
Message 6 of 9
Hallex
Do you want to scale all of the dimensions by the same scale factor?
~'J'~
Message 7 of 9
Hallex
Not sure about if this a right way, just a try
Option Explicit
Sub test()
     Dim oDimAlg As AcadDimAligned
     '' add other dim types here
     Dim scl As Double
     Dim setColl As AcadSelectionSets
     Dim setName As String
     Dim selMod As Long
     Dim gpCode(0) As Integer
     Dim dataValue(0) As Variant
     Dim dxfcode, dxfdata
          scl = Val(InputBox("Enter a scale: ", "Parameter Input", 0.25))
     On Error GoTo SayMeOnError
     gpCode(0) = 0
     dataValue(0) = "DIM*"
     dxfcode = gpCode: dxfdata = dataValue
     setName = "$Dims$"
     With ThisDrawing
          Set setColl = .SelectionSets
          For Each oSset In setColl
               If oSset.Name = setName Then
                    .SelectionSets.Item(setName).Delete
                    Exit For
          Next
          Set oSset = .SelectionSets.Add(setName)
     End With
     selMod = AcSelect.acSelectionSetAll
     oSset.Select selMod, dxfcode, dxfdata
     If oSset.Count = 0 Then Exit Sub
     oSset.Highlight True
     ' >> do your stuffs here
          Dim minpt As Variant
          Dim maxpt As Variant
          If TypeOf oEnt Is AcadDimRotated Or _
          TypeOf oEnt Is AcadDimAligned Then 'Or etc...
          Set oDim = oEnt
          oDim.GetBoundingBox minpt, maxpt
          oDim.ScaleEntity minpt, scl
          oDim.Update
     Next
ThisDrawing.Regen acActiveViewport
Set oSset = Nothing
SayMeOnError:
          If Err.Number <> 0 Then
     MsgBox Err.Description
End Sub
~'J'~
Message 8 of 9
Hi , Code given does help a lot. However, can you advise me how to identify/select the dimension with more specific criteria? For example: 1) Either by diemsnion's handle or ID 2) By text value (I'll preset the dimension which need to be change to something like X1,X2,X3...X40, then the code will replace these X1,X2... to the value i need) Btw, i do not need to scale the drawing or dimension.. It is a non scale drawing for outline dimension purpose only. Hope to get some advise. Thanks.
Message 9 of 9
Hallex
Sorry for the belating, but I have no idea about,
Smiley Sad
