Draw All Linetypes
Draw All Linetypes
Draw All Linetypes
I wrote this little sub in an effort to straighten out the linetypes we're using and thought it may be useful to someone else. If not, please ignore. Sub DrawEachLType() Dim vPnt As Variant, vFPt(2) As Double, vTPt(2) As Double Dim oLTyps As AcadLineTypes, oLTyp As AcadLineType Dim oLin As AcadLine, oTxt As AcadText vPnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "From point: ") vFPt(0) = vPnt(0): vFPt(1) = vPnt(1): vFPt(2) = 0# vTPt(0) = vPnt(0) + 5#: vTPt(1) = vPnt(1): vTPt(2) = 0# Set oLTyps = ThisDrawing.Linetypes For Each oLTyp In oLTyps vFPt(1) = vFPt(1) + 0.25 vTPt(1) = vTPt(1) + 0.25 Set oLin = ThisDrawing.ModelSpace.AddLine(vFPt, vTPt) oLin.Linetype = oLTyp.Name oLin.Update: Set oLin = Nothing Set oTxt = ThisDrawing.ModelSpace.AddText(" " & oLTyp.Name, vTPt, 0.1) oTxt.Alignment = acAlignmentMiddleLeft: oTxt.TextAlignmentPoint = vTPt oTxt.Update: Set oTxt = Nothing Next oLTyp Set oLTyps = Nothing End Sub
Greetings,
I'm a little ignorant on running subs in AutoCAD.
How would the average person use this code? I'm guessing I'd copy into an empty file, save it as something and then AP load it in AutoCAD?
Thanks!
Yeah. Have you tried it?
___
wrote in message news:5055497@discussion.autodesk.com...
load it in AutoCAD?
Tools>Macro>VBA Manager
then New
Select AcadProject
Then Visual Basic Editor
Under VBE >Insert>module
Past the code
Goback to Autocad and VBA manager
Select acadProject > Saveas
Then Macros
Select the appropriate Macro then Run
ALL done
Wow, I would have never haven't gotten that. I've used the VBE for Microsoft Office stuff but never in AutoCAD.
Thanks so much to everyone for posting this code and helping me run it!
Tom K.
Hi mfauxock,
It's good tutorial,thanks a lot for you,I'd like that.
wrote in message news:5055873@discussion.autodesk.com...
then New
Select AcadProject
Past the code
Then Macros
ALL done
