Displaying a 0
Displaying a 0
Displaying a 0
I must be having a programming block, because I cannot for the life of me figure this out, and I know it's a simple solution.
I have code that updates a zone table block with attributes.
When the macro is run, if there are no polylines on certain layers or those polylines have areas that round down to 0 square feet, the macro updates the attributes with nothing.
My boss would like to see a 0.  Here is the code I have:
                If TypeOf oEnt Is AcadLWPolyline Then
                     If oEnt.Layer = USFLay Then
                        dblUSF = dblUSF + oEnt.Area / 144
                    Else
                        If oEnt.Layer = UNSFLay Then
                            dblUNSF = dblUNSF + oEnt.Area / 144
doglips
I'm not exactly sure what variable is returning what but how 'bout something like this
  if dblusf < 1 then
   dblusf = 0
  end if
  Else
  if dblunsf < 1 then
   dblunsf = 0
  end if
Doglips, you've helped me yet again.
It wasn't your solution exactly that worked, but it helped me figure out that I needed to add if-then-elses to my string formatting that comes after the snippet I posted.
Thanks again.
doglips
Glad to help.
It doesn't matter how you get there... as long as you get there 🙂
