Display Extents
Display Extents
Display Extents
Does anyone know how to return the display extents in VB.
It is possible to see the values required when you use the status command,
the values are given the heading Display Shows. If anyone knows how to
return these values in VB please let me know.
Thanks....
William Hutchins
GIS Technician
CA DESIGN SERVICES LTD
The Design Centre, Hewett Road, Gapton Hall, Great Yarmouth, Norfolk,
NR31 0NN. Registered in England No. 1595687
mailto:WHutchins@cadesign.demon.co.uk
Phone: 01493 440444
Fax: 01493 442480
William,
Here is sample VBA code:
Public Sub test()
'view center in WCS
ctr = ThisDrawing.GetVariable("VIEWCTR")
'convert in to DCS
ctr = ThisDrawing.Utility.TranslateCoordinates(ctr, acWorld, acDisplayDCS,
0)
'height of the viewport in DCS
h = ThisDrawing.GetVariable("VIEWSIZE")
minp = ctr: maxp = ctr
'calculate the width of the viewport in DCS
vph = ThisDrawing.ActiveViewport.Height
vpw = ThisDrawing.ActiveViewport.Width
w = vpw * h / vph
'calculate bounding view boundary in DCS
minp(0) = ctr(0) - w / 2
maxp(0) = ctr(0) + w / 2
minp(1) = ctr(1) - h / 2
maxp(1) = ctr(1) + h / 2
'show that the points are indeed the ones we are looking for
minp = ThisDrawing.Utility.TranslateCoordinates(minp, acDisplayDCS, acWorld,
0)
maxp = ThisDrawing.Utility.TranslateCoordinates(maxp, acDisplayDCS, acWorld,
0)
ThisDrawing.ModelSpace.AddLine minp, maxp
End Sub
Hope this helps.
Cheers,
Thilak
William Hutchins wrote in message
news:ef074c1.-1@WebX.SaUCah8kaAW...
> Thanks....
> William Hutchins
> GIS Technician
> Phone: 01493 440444
> Fax: 01493 442480
ZoomExtents
William Hutchins je v sporoèilu novic
ef074c1.-1@WebX.SaUCah8kaAW napisal ...
> Thanks....
> William Hutchins
> GIS Technician
> Phone: 01493 440444
> Fax: 01493 442480
Thilak:
btw: I enjoyed reading your MSG... because you do give out a good tips.
amy
Thilak wrote in message ...
>William,
>Public Sub test()
>'view center in WCS
>'convert in to DCS
>0)
>w = vpw * h / vph
acWorld,
>0)
acWorld,
>0)
>End Sub
>Hope this helps.
>Cheers,
>Thilak
command,
>> Thanks....
>> William Hutchins
>> GIS Technician
>> Phone: 01493 440444
>> Fax: 01493 442480
