Disable the VPMAX command
I am using Autocad 2005 and have some commands that issue automatically. I have found that if I try to use the VPMAX command that autocad will bomb out and simple vanish, no errors or anything, so I would like to disable the vpmax command. The prolem I have is that autocad doesn't even recognize the command unless I am in paper space, so I can't issue an undefine command on start up. Any ideas?
GTVic
VPMAX is not a command until ACVPMAXMIN.ARX is loaded. The first time you use it the ARX is loaded and then it is a command. AutoCAD recognizes the comand when you are in model space - it just prints an error message.
Try this in your startup:
(arxload "acvpmaxmin")
(command "undefine" "vpmax")
It would be better to fix the crashing problem than to try and disable a command.
What does VPMAX have to do with commands that issue automatically - you were not too clear on that?
