Dir -> Error 70 - Permission Denied
Anyone seen this before? I'm sure someone else has. Apparently Dir doesn't
let go of the folder it searches until it finds the last match, which is not
a problem using exact matches or even single character wildcards, but can be
using multiple character wildcards. See the attached test sub. Hopefully
this will prevent someone else headaches down the road. I'm using VBA.
James Allen
Malicoat-Winslow Engineers, P.C.
Columbia, MO
arcticad
'This has always bothered me.
'Make a folder with files names 1.txt 2.txt .... 6.txt
Function dirit()
Dim Str, msg, v1, v2, v3
fPath = "c:\count"
v1 = Dir(fPath & "\*")
v2 = Dir
Debug.Print
v3 = Dir
MsgBox v1 & v2 & v3
End Function
'The result is 1.txt3.txt6.txt
'Dir is iterating the next item for everyline of code
I use this now to do searches.
You can change the search paths
Public Declare Function SearchPath Lib "kernel32" _
Alias "SearchPathA" _
(ByVal lpPath As String, _
ByVal lpFileName As String, _
ByVal lpExtension As String, _
ByVal nBufferLength As Long, _
ByVal lpBuffer As String, _
ByVal lpFilePart As String) As Long
Public Function FindFile(FileName As String) As String
Dim sPath As String, retVal As Long
Dim lpBuffer As String, nCount As Integer
nCount = 255
lpBuffer = Space(nCount)
sPath = AcadApplication.path & ";" & AcadApplication.Preferences.files.SupportPath
retVal = SearchPath(sPath, FileName, 0, nCount, lpBuffer, lpFilePart)
If retVal Then FindFile = left(lpBuffer, retVal)
End Function
(defun botsbuildbots() (botsbuildbots))
Have you tested your Findfile function?
Sorry, but I think it stinks, try yourself
Tested on A2005-2007
~'J'~
arcticad
It works perfectly fine for me.
Hello articad
Sorry if so
This is a strange matter, okay, forget about
Btw, API function SearchTreeForFile will be
work good I think
~'J'~
