Detecting right mouse click or enter key
Message 1 of 9
could some please help me exit this loop...
Do
Set returnObj = Nothing
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select text to be
changed: "
If returnObj.ObjectName = "AcDbText" Then
Set AllTextObj(intK) = returnObj
AllTextObj(intK).Highlight (True)
intK = intK + 1
ElseIf returnObj.ObjectName = "AcDbMText" Then
intK = intK + 1
Else
MsgBox "You must select a text object."
Loop
What I want to do is exit the loop if the user right mouse clicks or press
enter on the keyboard. But I also need to know if the user pressed the esc
key so I can't test to see if the GetEntity failed. Any ideas....???
Kevin K. Rhines
Replies (8)
Message 2 of 9
Kevin, Check out the error handling routine in the GetXX class on
www.acadx.com You can take a look at the way I've done it there. I'm sending
him the latest version of the class today.
Jacob Dinardi
"Kevin K. Rhines" wrote in message
news:5FDA08E6B30A69AC501BB28CE99EFA22@in.WebX.maYIadrTaRb...
> Do
> changed: "
> intK = intK + 1
> intK = intK + 1
> Else
> End If
> Loop
esc
> Kevin K. Rhines
Message 3 of 9
Thanks, I think that this will work.
Kevin
"Jacob Dinardi" wrote in message
news:4EF0A0E4289AEA9C212E67A5BE7F2021@in.WebX.maYIadrTaRb...
sending
> Regards,
> Jacob Dinardi
> > Do
> > changed: "
> > intK = intK + 1
> > intK = intK + 1
> > Else
> > End If
> > Loop
press
> esc
> > Kevin K. Rhines
Message 4 of 9
Jacob,
The code works great, but I should have been more specific I guess with
my question. What I would really like to do is have the code run more like
AutoCAD's change command. Were as I could select multiple entities and use
a crossing window. Any other idea's or am I simply at a dead end?
Kevin
news:0502E88053D1CA3C9CB266BDF9368362@in.WebX.maYIadrTaRb...
> Kevin
> sending
> > Regards,
> > Jacob Dinardi
> > > Do
> > > changed: "
> > > intK = intK + 1
> > > intK = intK + 1
> > > Else
> > > End If
> > > Loop
> press
the
> > esc
> > > Kevin K. Rhines
Message 5 of 9
news:3DB713B616C0B6C3CC34BCAAF2EE07FD@in.WebX.maYIadrTaRb...
> Jacob,
with
like
use
I'm a bit confused by what you're asking, given the
original code snippet you posted (detecting how the
user responded to a GetEntity() call).
What exactly do you mean by select multiple entities using
a crossing window, in the context of your original code?
If you want to allow multiple selection using a crossing
window, you can use AcadSelectionSet to do it. Is that
what you had in mind?
Message 6 of 9
You need to create a selection set with SelectOnScreen, which GetXX does not
support yet (Chuck Gabriel and I have been working on it). I believe there
is an arx resource written by Tony T. called acadx.arx (no relation to
acadx.com) that does support this as well as a number of other features.
Sorry I don't have a link for you though.
Jacob
> Jacob,
with
like
use
> Kevin
> > Kevin
> > sending
> > > Regards,
> > > Jacob Dinardi
> > > > Do
> > > > changed: "
> > > > intK = intK + 1
> > > > intK = intK + 1
> > > > Else
> > > > End If
> > > > Loop
> > press
> the
> > > esc
ideas....???
> > > > Kevin K. Rhines
Message 7 of 9
thanks I will take a look.
Kevin K. Rhines
news:728C6F6F8AB5A437E19C63AF54F5446D@in.WebX.maYIadrTaRb...
not
> Jacob
> > Jacob,
> with
> like
> use
> > Kevin
> > > Kevin
> > > sending
> > > > Regards,
> > > > Jacob Dinardi
> > > > > Do
be
> > > > > changed: "
> > > > > intK = intK + 1
> > > > > intK = intK + 1
> > > > > Else
> > > > > End If
> > > > > Loop
or
> > > press
pressed
> > the
> > > > esc
> ideas....???
> > > > > Kevin K. Rhines
Message 8 of 9
Tony,
Sorry for the confusion I originally did use selection set, but again
how do I detect that the user has pressed the enter key or right mouse
clicked?
Kevin K. Rhines
"Tony Tanzillo" wrote in message
news:96575CF1B1F00BF14FAD3473545EB422@in.WebX.maYIadrTaRb...
> > Jacob,
> with
> like
> use
Message 9 of 9
The right mouse is configurable to display context
menus, or issue the command assigned in the AUXxxx
menu (or ENTER), so it is not simply a matter of
detecting a right-click.
For finding out how the user exited selection, the
ERRNO system variable might be of use.
news:48A45018794B40B1F551B514A1123F68@in.WebX.maYIadrTaRb...
> Tony,
> clicked?
> Kevin K. Rhines
> > > Jacob,
> > with
> > like
and
> > use
