Declaring Variables once for Entire VBA Project
Is there a way to declare variables once, for an entire project? If I am using the same variable in a lot of forms i do not want to declare it everywhere.
declare your variable(s) as Public in a Code module.
Im assuming the variables you are referring to have to do with autocad, or something in-house, but do NOT refer to things actually having to do with a form/interface. If the latter is the case, youll *want* individual copies of each variable.
I am wanting to declare variables for AcadEntity and AcadBlockReference to name a few (there are several)....the same variable i am setting is used in several forms....you are suggesting a create a "CODE" module?
A standard .bas file using Public or Global
variables [do not create them in any of your Form modules].
Joe ...
I
Hi Joe, Any Plans for an Acad2009 release of your VBA Book? I have both the 06 and 04 versions
No, but I have been working on some .NET
material.
Joe ...
Hi
and 04 versions
