Creating Typeable Commands for VBA Routines?
Any good ideas for creating "command line" commands to fire up VBA
Macros? I have been trying to use Vlisp commands (defun c:doit ...
because they can load my DVB and fire up the macro like this ...
(vla-LoadDVB acadApp advbFile)
(vla-RunMacro acadApp myMacro)
... but problems have arisen with .SelectOnScreen (above post) as well
as not being able to close the current drawing (because LISP has it
"BUSY").
Thanks in advance,
Terry
Hi Terry,
I use something like this:
(defun c:mycommand()(command "-vbarun" "myproject.dvb!mymacro"))
The macro path has to be in the support files search path to work as shown.
Bud Miller
www.BudCAD.com
AutoCAD & LDD apps and more
"Terry W. Dotson" wrote in message
news:3B13BF96.D9E0499C@dotsoft.com...
> "BUSY").
> Thanks in advance,
> Terry
Terry
You might want to take a look at this
http://pointa03.autodesk.com/kdn/content/solutions/58357.htm
Kent
> "BUSY").
> Thanks in advance,
> Terry
That fixes my SelectOnScreen problem!
Thanks, Terry
I have been using the following
(vl-vbarun "advbFile.dvb!myMacro")
I overcomes the SelectOnScreen failure without forcing you to use the
"command" function.
The down side is, you can't preselect objects with this method.
Chuck
> "BUSY").
> Thanks in advance,
> Terry
