Creating selection sets
Is there a way to create a selection of only one object? I have a routine
that I want the user to be able to only pick one object and then continue
the remaining code. This way I won't have to cycle through the selection
set.
Ed__Jobe
Use the GetEntity method. You don't even need to use a selection set. It returns the entity.
Ed
How to post your code.
Thanks,  If I only new it was that
easy.
Use
the entity.
Another question, is there a way to use the
GetEntity method and filter on the object type or xdata?
Use
the entity.
Ed__Jobe
No, but you can easily check the object's type and prompt again if it's not what you want.
Ed
