Creating Objects
Creating Objects
Message 1 of 8
Creating Objects
I know I can create my own custom objects and collections using class
modules. Can you create a displayable custom AutoCAD object and insert it
into a drawing?
I'd like to be able to draw "widget" object (say a displayable line) that
has all the properties of a line object (like layer, linetype, and geometry
data), but also has other properties and methods, like .density or
.materialtype. I know I can attach Xdata to objects (like dictionaries),
but I'd like to encapsulate these properties for easy code manipulation.
I hope I am making sense to someone.
So, can you do this in VBA? If not, what is the right tool to create these
new objects?
Thanks, Brian
Replies (7)
Message 2 of 8
You can't create custom objects without ObjectARX. I think the easiest way
would be to use XData. You could also create some function to help the
manipulation of XData, for example:
Public Function GetDensity(pLine as AcadLine) as Double
'Extracting XData
End Function
Public Sub SetDensity(pLine as AcadLine, pDensity as Double)
'Setting XData
End Function
Alain
"Brian Johnson" wrote in message
news:BE1BC1B7D908180FE53D65D4657504E7@in.WebX.maYIadrTaRb...
> Hello,
> into a drawing?
geometry
these
> new objects?
> Thanks, Brian
Message 3 of 8
That's what I thought.
I have never messed with OjectARX. Is there a handy-dandy development
interface like VBA? How does ObjectARX relate to VBA and AutoCAD in terms
of development?
Thanks again!
Brian
"Alain Bouchard" wrote in message
news:9130877F76368B31DB4463504744A68A@in.WebX.maYIadrTaRb...
> 'Extracting XData
> End Function
> 'Setting XData
> End Function
> Alain
> > Hello,
it
> > into a drawing?
that
> geometry
dictionaries),
> these
> > new objects?
> > Thanks, Brian
Message 4 of 8
Then, stay away from it unless you absolutely need it.
> Is there a handy-dandy development interface like VBA?
Nope. You need VC++ 6.0.
>How does ObjectARX relate to VBA and AutoCAD in terms of development?
A totally different object model and a totally different programming
approach. VB(A) is easy to use but less efficient. ObjectARX is more
efficient but you can crash AutoCAD easily.
____________________________________
Alain Bouchard, M.Sc.
Software Developer
Digital Photogrammetry Lab
Pavillon Casault
Laval University
G1K 7P4
Alain.Bouchard@scg.ulaval.ca
Message 5 of 8
Thanks for the info Alain.
-Brian
news:F924C8082A68DD302F63FFE22DE242BE@in.WebX.maYIadrTaRb...
> Software Developer
> Pavillon Casault
> Laval University
> G1K 7P4
Message 6 of 8
Are you sure you CANNOT create custom objects using VBA? I was glancing through a tutorial on this very subject on the VIP Point A site which showed you how to do it.
Message 7 of 8
You can create your own *classes* (and therefore objects) but these
are not custom drawing entities. An example of a custom object is
ARCTEXT. There is no way to create such an object with VB or VBA.
http://www.acadx.com
"jbryant4" wrote in message
news:f0499da.4@WebX.maYIadrTaRb...
Message 8 of 8
With ObjectARX you can create your custom objects and AutoCAD gladly accepts as if its own entity.
With use of ATL (Active Template Library, I really do not know much about it) you can expose your objects to VBA. Also, with OPM you can get property sheet for your custom objects much like regular AutoCAD objects. These are just few of lot great things you can do with ObjectARX on custom onject front. Again, exposing your custiom objects to VBA helps lower programming cader to "play" with your object like -
DIM elbow as AcdbElbow or
DIM flange as AcdbFlange and then set properties like
Set flange.size = 4" or flange.rating = 300# and things like that.
Go for ObjectARX if you want to make real life objects.
Nimish
