Creating Menus in VBA
Message 1 of 9
I am Developing User Interface in VBA for AutoCAD but I am not able to
create Menus as we do it in Visual Basic by going into Tools--> Menu Editor,
there is no such Menu Editor in VBA. can anybody please advice.
Sanjay
Replies (8)
Message 2 of 9
Correct. No menu's available in VBA.
Regards - Nathan
Message 3 of 9
Uhmm, that's a little misleading. There is no VB-style (visual) menu editor
available in AutoCAD's VBA. You can, however, work with the AutoCAD main
menu bar, sub-menus, and tool bars jsut fine. Take a look in the help file
here:
Developers Help
ActiveX and VBA Developer's Guide
Customizing Toolbars and Menus
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
wrote in message news:[email protected]...
Regards - Nathan
Message 4 of 9
Not misleading at all. Modifying AutoCAD's menus is not the same as being able to add menus to your own form.
Regards - Nathan
Message 5 of 9
Sanjay Jamalpur wrote in
news:[email protected]:
> Editor, there is no such Menu Editor in VBA. can anybody please
> advice.
> Thanks
> Sanjay
You CAN add menus to VBA userforms by using the Windows API, see attached
JPG. It only works on modal forms although from reading other posts I think
you can not use modeless forms at all in Autocad.
Attached is a VBA sample project.
- Jose
Message 6 of 9
hmmmm, maybe that is why focus will not on my modeless form?
I've every which way to keep focus on my form with no luck. I want to be able to input into a text box.
Any ideas?
Message 7 of 9
RonnieWilkins
You will need to place the AcFocusCtrl onto your modelss userform in order for it to retain input focus.
In VBA, right-click on toolbox and choose Additional Controls...
Next 'x' the AcFocusCtrl control.
Finally drag the new control onto your modless dialog, it doesn't matter where at as it will be invisible at runtime.
Ronnie Wilkins, Jr.
Message 8 of 9
Thanks for that.
But it wasn't invisible at runtime, and I had to click on it in the form before it would stay focused.
Using ADT 2006
Message 9 of 9
Well, after toggling in visible property of the control, it works as you have decribed now
