Creating a Camera and making an animation (Anipath) in .NET
Message 1 of 1
Hey!
Since I'm stuck with my code and can't find the answer myself, I hope you can help me.
My goal is to make a .dll for AutoCAD, which is basicly a faster way to create an animation.
I want it to follow the next steps:
- (Active my function, I named it ANIMATE, got this working already)
- Creating a Camera, at which the user can select the begin and endpoint. Every other property can stay the default value.
- When the Camera is placed, activate Anipath. The user will be asked to select the animation path, the second reference a point and the animation time lenght. Everything else can stay the default value.
- At last export this animation.
I wasn't able to find anything of use in the object library to activate this commands by code. I ended up with:
 _doc.SendStringToExecute("CAMERA ", False, False, True)
 Which probably isnt any good.
Well, many many thanks in advance!!!
Replies (0)
