Create dxf from selected objects
is there a way to do this with code?
using either a selection set/ a collection / or an array of entities, export
them to a dxf file
I'm going to try calling document.Wblock method but don't see an argument to
specify drawing type so don't know how that will work
meanwhile if anyone has an answer I'd be much abliged
thanks
mark
norman.yuan
Of couse WBlock will only create a *.dwg file. But you simply need to go one stepo further: Once the Wblock is done, open the DWG file and save it as a DXF file.
Norman Yuan
Drive CAD With Code
right, it's been a while since i looked at the available drawing type
enums...hope there's one for dxf2007 then i could program that step
too....will look there next
thanks for the confirmation
mark
wrote in message news:6368134@discussion.autodesk.com...
DXF file.
