create block
create block
create block
'question  !!!!!!!!
' to create selection set there is SelectOnScreen  Line 50
'I want to write down in program select linia linia1 linia2
' without clicking mouse on screen
' How to add  linia linia1 linia2 to my block without using my muouse
' i want to write program that will add these lines
Public Sub TestCopyObjects1()
Dim objSS As AcadSelectionSet
Dim varBase As Variant
Dim objBlock As AcadBlock
Dim strName As String
Dim strErase As String
Dim varEnt As Variant
Dim objSourceEnts() As Object
Dim varDestEnts As Variant
Dim dblOrigin(2) As Double
Dim intI As Integer
With ThisDrawing.Utility
Dim k0Deg, k60Deg, k120Deg As Double
k0Deg = .AngleToReal("0d", acDegrees)
k60Deg = .AngleToReal("60d", acDegrees)
k120Deg = .AngleToReal("120d", acDegrees)
Const od100p As Integer = 100
Dim pktP0, pktP1, pktP2, pktP3 As Variant
pktP0 = .GetPoint(, vbCr & "Pick the start point: ")
pktP1 = .PolarPoint(pktP0, k0Deg, od100p)
pktP2 = .PolarPoint(pktP0, k60Deg, od100p)
pktP3 = .PolarPoint(pktP0, k120Deg, od100p)
Dim linia, linia1, linia2 As AcadLine
Set linia = ThisDrawing.ModelSpace.AddLine(pktP0, pktP1)
Set lini1 = ThisDrawing.ModelSpace.AddLine(pktP0, pktP2)
Set linia2 = ThisDrawing.ModelSpace.AddLine(pktP0, pktP3)
 End With
    'choose a selection set name that you only use as temporary storage and
    'ensure that it does not currently exist
On Error Resume Next
    ThisDrawing.SelectionSets.Item("TempSSet").Delete
    Set objSS = ThisDrawing.SelectionSets.Add("TempSSet")
    objSS.SelectOnScreen '!!!!!!!!!!!!!!!!!!!!!!!
    '' get the other user input
        .InitializeUserInput 1
        strName = .GetString(True, vbCr & "Enter a block name: ")
        varBase = .GetPoint(, vbCr & "Pick a base point: ")
    End With
    '' set WCS origin
    dblOrigin(0) = 0: dblOrigin(1) = 0: dblOrigin(2) = 0
    '' create the block
    Set objBlock = ThisDrawing.Blocks.Add(dblOrigin, strName)
    '' put selected entities into an array for CopyObjects
    ReDim objSourceEnts(objSS.Count - 1)
    For intI = 0 To objSS.Count - 1
        Set objSourceEnts(intI) = objSS(intI)
    Next
    '' copy the entities into block
    varDestEnts = ThisDrawing.CopyObjects(objSourceEnts, objBlock)
    '' move copied entities so that base point becomes origin
    For Each varEnt In varDestEnts
        varEnt.Move varBase, dblOrigin
    Next
   '' clean up selection set
    objSS.Delete
End Sub
norman.yuan
You, of course, do not need to select entities on the screen, because the targeting entities are created in your code and you have the referneces to them. You can use AcadSelectionSet.AddItems() to add these entities into the selection set. That is (psuedo code):
'Create an AcadSelectionSet here
' Declare an array
Dim ents(0 to 2) As Entity
''Create the lines and place them into the array
Dim line As AcadLine
Set line = ThisDrawing.ModelSpace.AddLine(pktP0, pktP1)
ents(0)=line
Set line = ThisDrawing.ModelSpace.AddLine(pktP0, pktP2)
ents(1)=line
Set line = ThisDrawing.ModelSpace.AddLine(pktP0, pktP3)
ents(2)=line
''Add these lines into AcadSelectionSet
objSS.AddItems ents
However, since you use CopyObject() to build the block, you DO NOT NEED a SelectionSet, you simply use the entity array:
''Add lines into the block
varDestEnts = ThisDrawing.CopyObjects(ents, objBlock)
Norman Yuan
Drive CAD With Code
Debugger shows   ents(0) = linia  is incorrect
I am novice about VBA and I don't know how to cope
'question  !!!!!!!!
Dim intI As Integer
Dim ents(0 To 2) As AcadEntity  ' Declare an array
Set linia1 = ThisDrawing.ModelSpace.AddLine(pktP0, pktP2)
ents(0) = linia
ents(1) = linia1
ents(2) = linia2
 End With
    objSS.AddItems ents  '!!!!!!!!!!!!!!!!!!!!!!!
    End With
    '' set WCS origin
    '' create the block
    Next
    objSS.Delete
End Sub
norman.yuan
There is because of this line:
This Dim statement only declares linia2 as AcadLine, while linia and linia1 are Variant,
It should be
Dim linia As AcadLine
Dim linia1 As AcadLine
Dim linia2 As AcadLine
Or simply only use one Dim statement as my previous reply shows.
Norman Yuan
Drive CAD With Code
unfortunately it doesn't work
please try this code in your debugger
norman.yuan
Well, it is just a simple error:
change
ents(0)=linia
To
Set ents(0)=linia
Here is the code works for me:
Option Explicit
Public Sub Test()
  Dim ents() As AcadEntity
  ents = CreateLines()
  ''Create block
  Dim blk As AcadBlock
  Dim pt(0 To 2) As Double
  pt(0) = 0#: pt(1) = 0#: pt(2) = 0#
  Set blk = ThisDrawing.Blocks("TestBlock")
  If Err.Number <> 0 Then
    Set blk = ThisDrawing.Blocks.Add(pt, "TestBlock")
  ThisDrawing.CopyObjects ents, blk
End Sub
Private Function CreateLines() As AcadEntity()
  Dim pt1(0 To 2) As Double
  Dim pt2(0 To 2) As Double
  pt1(0) = 0#: pt1(1) = 0#: pt1(2) = 0#
  pt2(0) = 0#: pt2(1) = 5#: pt2(2) = 0#
  Set line = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
  Set ents(0) = line
  pt2(0) = 5#: pt2(1) = 0#: pt2(2) = 0#
  Set ents(1) = line
  pt2(0) = 5#: pt2(1) = 5#: pt2(2) = 0#
  Set ents(2) = line
  CreateLines = ents
End Function
Norman Yuan
Drive CAD With Code
Thank You for help
It works
