Creat a polyline from database
nucliabrasil
nucliabrasil
Hello !
I have an access table and I have the east and north coordinates. I want to search the table and generate a polyline in autocad. How do I do ?
thankful
norman.yuan
The point/coordinate data being in database, or anywhere outside of AutoCAD should have no impact on how AutoCAD create a polyline (assume it is AcadLWPolyline usually). If you need to write code to do it, just remember to separate the code that somehow obtain the points/coordinates from somewhere, and the code that actually create the polyline (or any AcadEntity, for that matter).
Say, you have a separate code module that handle database access, which has a public function to return a double array, representing coordinates of a polyline, like this:
Public Function GetPolylineCoordinates(dbConnectionString As String) As Variant
    Dim coords() As Double
    '' use ADO (or DAO) to connect the Access DB and retrieve the data and fill out the variable "coords"
    GetPolylineCoordinates = coords
End Function
Then in another module, you can have a macro like this:
Public Sub DrawPolylineFromData()
    Dim dbConnection As String
    dbConnection = "???????????"  '' CnnectionString
    Dim coords As Variant
    coords=GetPolylineCoordinates(dbConnection)
    Dim pl As AcadLWPolyline
    Set pl = ThisDrawing.AddLIghtWeightPolyline(coords)
    '' set polyline's other properties, if necessary, such as Layer, Color..
   pl.Update
End Sub
Norman Yuan
Drive CAD With Code
nucliabrasil
Thanks norman,
but help me understand why it does not create the polyline in this code. What is missing?
Dim coords(0 To 1) As Double
Dim i As Integer
Conectar '<<< conection database
Set rsPP.ActiveConnection = dbcon
rsPP.Open "select * from pp", dbcon, adOpenStatic, adLockOptimistic
npts = rsPP.RecordCount
For i = 1 To npts
rsPP.Filter = "pt= '" & i & "'"
coords(0) = rsPP.Fields("cx")
coords(1) = rsPP.Fields("cy")
Set pl = ThisDrawing.ModelSpace.AddLightWeightPolyline(coords)
If i = npts + 1 Then Exit For
Next i
norman.yuan
I assume you do know that to create a polyline, you need AT LEAST 2 points. That is, the coordinate array that is passed to AcadModelSpace.AddLightWeightPolyline() method MUST HAVE at least 4 elements.
In your code, each loop in the For...Next, you obtain 1 point (one x value, one y value), and then you try to create a LWPolyline with this ONLY point. I did not see you have "On Error Resume Next", and wondering why the AddLightWeightPolyline(coords) did not raise exception, as it should.
BTW, this line
is completely unnecessary: the "For i to npts"  already guarantees that the i will not go past npts!
I suspect that the x/y values in the recordset is meant to a single polyline with many vertices, and you use RecordSet filter to get points in order (you may sort the recordset in SQL statement rather than filter the recordset in each For... loop for better performance). If this is the case, code would be something like:
Dim coords() as double
Dim i as Integer
Dim j As Integer
'' Open and get RecordSet
For i = 1 to npts
  ''Get 1 point
  rsPP.Filter = "pt='" & i & "'"
  ''Add the point's X value and add it to the coordinate array
  Redim Preserve coords(j)
  coords(j)=rsPP!cx
  j = j + 1
  ''Add the point's Y value and add it to the coordinate array
  coords(j)=rsPP!cy
  j = j + 1
Next
'' Now you create a polyline with Vertex/point count = npts
'' with coordinate array with element count = 2 x npts
Set pl = ThisDrawing.AddLightWeightPolyline(coords)
HTH
Norman Yuan
Drive CAD With Code
nucliabrasil
Perfect norman.
It's worked with success !
Thanks !
