Copying selections or blocks
I'm working on a delphi application that works with autocad (tested with 2008 and 2009). Right now I need a command to either:
- Copy some selected items from one document and paste to another existing document, or
- Export blocks from one and import them to another existing document.
I've already been able to select all the items or blocks that I need, but I'm unable to find any command to export those selections to a new file, something like:
{code}selectedStuff.CopyToFile('filename', insertPoint1, insertPoint2, scale);{code}
or
{code}block.ExportTo('filename', insertPoint1, insertPoint2, scale);{code}
Right now I've gotten most of the info about autocad commands from VB programs, so any help on VB will be appreciated too.
Look at CopyObjects in the help files
hth
mark
wrote in message news:6181343@discussion.autodesk.com...
2008 and 2009). Right now I need a command to either: - Copy some selected
items from one document and paste to another existing document, or - Export
blocks from one and import them to another existing document. I've already
scale);{code} or {code}block.ExportTo('filename', insertPoint1,
insertPoint2, scale);{code} Right now I've gotten most of the info about
too.
