Copy_ODTables
Copy_ODTables
Copy_ODTables
Hi All,
I want to Copy OD Tables from one object to another.
Is there any way to do this in VBA. Thanks in Advance...
Basha
I assume by "ODTables" you mean Object Data Table (in Acad Map).
ODTable does not exists on the object/entity basis. It is per drawing based.
As long as the ODTable is defined, you can construct an Object data record
and attach it to selected entities.
So, you do not copy. You attach.
Look into:
ODTable.CreateRecord()
ODRecord.AttachTo()
wrote in message news:5642815@discussion.autodesk.com...
Hi All,
Basha
