Copy Objects
Copy Objects
grobnik
Copy Objects
grobnik
Hi to everybody,
I need some help from group.
Probably there is something of wrong in my action because the results it's null.
The scope should be copy a selection of objects from a drawing to another (new document).
In order to do this I developed the code below, but even if the object collection it's not empty on new document I never seeing any kind of object copied.
Dim sourceEnts()
'ssetObj it's coming from a previous selection set code, and it's not empty.
ReDim sourceEnts(ssetObj.Count - 1)
For i = 0 To ssetObj.Count - 1
    Set sourceEnts(i) = ssetObj(i)
Next
Dim DOC0 As AcadDocument
Set DOC0 = ThisDrawing.Application.ActiveDocument
Dim Doc1MSpace As AcadModelSpace
Dim DOC1 As AcadDocument
Set DOC1 = Documents.Add
Set Doc1MSpace = DOC1.ModelSpace
'' copy the source entities into destination modelspace
retObjects = DOC0.CopyObjects(sourceEnts, Doc1MSpace)
'' clean up selection set
ssetObj.Delete
Result of above it's only an empty document.
Thank you
norman.yuan
Well, since you did not show all code (how the selectionset is collected), it is hard to say what went wrong there. Did you step through the code and examine the variables in "Locals Window" to make sure you do not have an empty entity array? No error at all (assume you do not have "On Error Resume Next" that would hide any exception)?
Following complete code, which is only different from yours by how to gathering the entity array, works well:
Option Explicit
Public Sub CopyToNewDwg()
    Dim ents As Variant
    Dim sourceDwg As AcadDocument
    Dim destDwg As AcadDocument
    Dim returned As Variant
    Set sourceDwg = AcadApplication.ActiveDocument
    ents = CollectEnts(sourceDwg)
    If UBound(ents) < 0 Then
        MsgBox "No source entity found!"
        Exit Sub
    Set destDwg = AcadApplication.Documents.Add()
    returned = sourceDwg.CopyObjects(ents, destDwg.ModelSpace)
    AcadApplication.ZoomExtents
    MsgBox UBound(returned) + 1 & " entities were copied!"
End Sub
Private Function CollectEnts(doc As AcadDocument) As Variant
    Dim ents() As AcadEntity
    Dim ent As AcadEntity
    Dim i As Integer
    For Each ent In doc.ModelSpace
        ReDim Preserve ents(i)
        Set ents(i) = ent
        i = i + 1
    Next
    CollectEnts = ents
End Function
See the short video that proves its execution succeeds:
Norman Yuan
Drive CAD With Code
grobnik
Hi @norman.yuan ,
Thank you for your support, I'm confirming that all objects are into ssetObj array.
But starting from the fact that the variable contains objects, did you find something of wrong in my code ?
In any case see attached sample.
Code consist of a request of a polyline selection on screen, after that all objects inside the closed polyline will be stored in ssetObj variable by a SelectionSet.
However I'll try to apply your code and I'll let you know.
Thank you.
norman.yuan
Well, as I mentioned in my reply (as I guessed), it is the very common code error (out of habit of many VBA coders) that makes us blind to the obvious: using "On Error Resume Next" without cancel its effect when it is not needed any more.
Here is your code (by the way, here you somehow call the DestinationDwg.CopyObjects(), which really should have been called from SourceDwg, as the code shown in your original post. I assume it was just an error in rush):
Sub test_pl()
    'Dim ssetObj As AcadSelectionSet
    Dim oEnt As AcadEntity
    Dim Pt(0 To 2) As Double
    Dim oLWP As AcadLWPolyline
    Dim oP As AcadPolyline
    Dim dblNewCords As Variant
    ThisDrawing.SelectionSets.Item("TEST_SSET2").Delete
    ThisDrawing.Utility.GetEntity oEnt, Pt, "Select a polyline"
    Set oLWP = oEnt
    dblCurCords = oLWP.Coordinates
    iMaxCurArr = UBound(dblCurCords)
    iMaxNewArr = ((iMaxCurArr + 1) * 1.5) - 1
    ReDim dblNewCords(iMaxNewArr) As Double
    iCurArrIdx = 0: iCnt = 1
    For iNewArrIdx = 0 To iMaxNewArr
    If iCnt = 3 Then
    dblNewCords(iNewArrIdx) = 0
    iCnt = 1
    Else
    dblNewCords(iNewArrIdx) = dblCurCords(iCurArrIdx)
    iCurArrIdx = iCurArrIdx + 1
    iCnt = iCnt + 1
    Next
    Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET2")
    ssetObj.SelectByPolygon acSelectionSetCrossingPolygon, dblNewCords
    Dim sourceEnts()
    Next
    Dim SourceDwg As AcadDocument
    Set SourceDwg = ThisDrawing.Application.ActiveDocument
    Dim DestinationDwg As AcadDocument
    Set DestinationDwg = Documents.Add
     DestinationDwg.CopyObjects sourceEnts, SourceDwg.ModelSpace
Done:
    ssetObj.Delete
End Sub
Below is my modified code with highlight/comment on what happens:
Option Explicit  '' I added this. I am sure you agree and only missed it because of rushing for test code
Sub test_pl()
  Dim dblCurCords As Variant
  Dim iMaxCurArr As Integer
  Dim iMaxNewArr As Integer
  Dim iCurArrIdx As Integer
  Dim iNewArrIdx As Integer
  Dim iCnt As Integer
  On Error Resume Next '' This is the devil caused trouble. See later comment
  On Error GoTo 0  '' Remove the "On Error Resume Next" effect after its intention
  Set oLWP = oEnt
    If iCnt = 3 Then
      iCnt = 1
    Else
      iCnt = iCnt + 1
  Next
  '' This is source of the error: the CopyObjects requires arry of AcadEntity, not array of Varaint
  '' this causes CopyObjects() method failed, but because of "On Error Resume Next", you did not notice the error
  '' Dim sourceEnts()
  Dim sourceEnts() As AcadEntity  '' As long as I made this change, the code worked
  Dim i As Integer
  Next
  ssetObj.Delete
  '' I assume you made this line wrong because of rushing test code
  '' DestinationDwg.CopyObjects sourceEnts, SourceDwg.ModelSpace
  SourceDwg.CopyObjects sourceEnts, DestinationDwg.ModelSpace
End Sub
It is very common that a programmer, no matter how experienced one could be, may totally blind to see the obvious from his/her own code, but has sharper eyes to scan others' 😪
Norman Yuan
Drive CAD With Code
grobnik
Hi @norman.yuan ,
it's working perfectly now ! the routine was a mix of several code copied and paste in an unique module, I'm not a professional programmer.
Thank you.
Bye
