Copy objects from one drowing to another - GetInterfaceObject method.
Hello. I'm using this function to copy blocks from one drawing to another. It works in AutoCAD 2004, 2006 but I need to know whether will it work in AutoCAD 2010. This is the code that I use and my question is if I add these lines to check version is the method will work or not.
If Left(Application.Version, 2) = "18" Then
    Set oDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.18")
Here is the full program:
Private Sub CopyBlock(BlockName As String)
     Dim oDbx As Object
        ' 2007 - 2009 ver.
        If Left(Application.Version, 2) = "17" Then
           Set oDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.17")
        ' 2004 - 2006 ver.
        If Left(Application.Version, 2) = "16" Then
           Set oDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
     Dim fname As String
           fname = "C:\BojkoCAD\blocks.dwg"
           oDbx.Open fname
     Dim oBlocks As AcadBlocks
     Dim oBlock As AcadBlock
     Dim copyVar(0) As AcadBlock
     Set oBlocks = oDbx.Blocks
     Set oBlock = oBlocks.Item(BlockName)
     Set copyVar(0) = oBlock
On Error GoTo problem
     Dim idPairs As Variant
     Dim copyBLK As Variant
            copyBLK = oDbx.CopyObjects(copyVar, ThisDrawing.Blocks, idPairs)
     Set oDbx = Nothing
problem:
     If Err.Number <> 0 Then
        MsgBox "ObjectDBX CopyObjects method objects failed." & vbCr & Err.Number & " " & Err.Description, vbCritical, "BojkoCAD"
End Sub
Hallex
Just an idea not tested
Set oDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.18.2")
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thank you I test it and works fine.
Hallex
Glad to help
Happy coding Smiley Happy
~'J'~
