Copy Nightmare
Copy Nightmare
Copy Nightmare
One last go - all of the next process needs to be done in VBA.
I need to open a drawing, select everything in model space, copy it and then open a new drawing based on a specific template and paste everything back into model space. Then save the drawing. I can't get me head around how to copy everything and then open a drawing based on a template. Alot of the examples shown here need a screen selection but I need to do the select all automatically. If anyone can assist I will be very grateful
How about something like this? Note that there is no error checking and the
code to save the new drawing is not included.....this is merely an example
for you to use that does what you are trying to do.
Sub copyMSpace()
Dim oEnt As AcadEntity
Dim vEnts() As AcadEntity
Dim oLayer As AcadLayer
Dim I As Long
Dim oDwg1 As AcadDocument
Dim oDwg2 As AcadDocument
Set oDwg1 = Application.ActiveDocument
For Each oLayer In oDwg1.Layers
If oLayer.Lock = True Then oLayer.Lock = False
Next
ReDim vEnts(0 To oDwg1.ModelSpace.Count)
For Each oEnt In oDwg1.ModelSpace
Set oLayer = oDwg1.Layers.Item(oEnt.Layer)
If (oLayer.Freeze = False) And (oLayer.LayerOn = True) Then
Set vEnts(I) = oEnt
I = I + 1
Next
ReDim Preserve vEnts(0 To I - 1)
If oDwg1.GetVariable("SDI") = 0 Then
Set oDwg2 = Application.Documents.Add("ACAD.DWT")
Else
Set oDwg2 = oDwg1.New("ACAD.DWT")
oDwg1.CopyObjects vEnts, oDwg2.ModelSpace
End Sub
wrote in message news:5065429@discussion.autodesk.com...
Jeff,
Your code works great, I really appreciate your mail.
Thanks for taking the time to solve me problem.
Regards
Ian
