Converting Circles on a layer into REGIONS???
Message 1 of 10
I have plenty of circles on a layer. I want to convert them into REGIONS. I am using following code. [[[[[[[[Public Sub CreateRegion(ByVal sLayName As String) On Error Resume Next Dim currLayer As AcadLayer Set currLayer = ThisDrawing.Layers.Item("Optimal region") ThisDrawing.ActiveLayer = currLayer Set CrtRegion = ThisDrawing.SelectionSets.Item(sLayName) If Err Then Err.Clear Set CrtRegion = ThisDrawing.SelectionSets.Add(sLayName) 'Else 'gsset.Clear 'gsset.Delete End If 'define type of selection set (crossing, window, etc, in this case, all) Dim mode As Integer mode = acSelectionSetAll 'this is a selection set filter Dim gpCode(0) As Integer Dim dataValue(0) As Variant gpCode(0) = 8 dataValue(0) = sLayName 'this is selection set filter data Dim groupCode As Variant, dataCode As Variant groupCode = gpCode dataCode = dataValue 'this collects all objects on 'sLayName' layer into the seletion set CrtRegion.Select mode, , , groupCode, dataCode Dim Arr As Variant Dim NumOfCircles As Integer NumOfCircles = CrtRegion.Count ReDim Arr(0 To CrtRegion.Count - 1, 1) Dim index As Integer Dim Obj As AcadCircle Dim regionObj As Variant For index = 0 To NumOfCircles - 1 Set Obj = CrtRegion.Item(index) regionObj = ThisDrawing.ModelSpace.AddRegion(Obj) Next index CrtRegion.Clear CrtRegion.Delete End Sub]]]]]]]]]]]]]]] Thanks Mniaz
Replies (9)
Message 2 of 10
    If Err Then
        Err.Clear
        'Else
        'gsset.Clear
        'gsset.Delete
    Dim mode As Integer
    gpCode(0) = 8
    groupCode = gpCode
    Dim Arr As Variant
    Next index
CrtRegion.Clear
CrtRegion.Delete
Mniaz
Message 3 of 10
my example to you was just on how to select items on a certain layer.
that selects all items, not just circles. If you only wanted circles on
that layer you need to make your filter more specific
Dim gpCode(1) As Integer
Dim dataValue(1) As Variant
gpCode(0) = 8
gpCode(1) = 0
dataValue(1) = "CIRCLE"
also re-read the help file on AddRegion,
it expects an array of objects, not an object as it's input parameter
"mniaz" wrote in message
news:f19b1a9.-1@WebX.maYIadrTaRb...
dim arObj(0) as AcadCircle
if you want a separate region for every circle
Set arObj(0) = CrtRegion.Item(index)
regionObj = ThisDrawing.ModelSpace.AddRegion(arObj)
Next index
Message 4 of 10
Actually on one layer i have only circles, so i used the above code. I am done with converting circles into regions, your tip helped me a lot.
No my only problem is "INTERSECT Regions". Kindly see new post.
Mniaz
Message 5 of 10
Mniaz,
I figured that was the case.
I only mentioned the more general method because it may not always be the
case
and if you're writing functions you may want to use in the future, it's good
to consider various conditions and try to write in such a way that code can
be reused with only supplying varying inputs, not having to rewrite the code
itself to match each specific need.
If i were you, I'd be separating the code parts into reusable functions,
even though it's not necessary this time, it may come in handy in the future
eg:
sub SelectObjects(objectType, objectLayer) ... etc
then this time you'd call
SelectObjects acadCircle, strLayer
next time you might need
SelectObjects acadLine, strOtherLayer
does that make sense?
news:f19b1a9.2@WebX.maYIadrTaRb...
> Thanks
> Mniaz
Message 6 of 10
did you read the last part of my previous answer? re object arrays?
Message 7 of 10
I got your point which weighs more than what i was thinking. I am trying to make it general.
Thanks for your guidance.
Mniaz
Message 8 of 10
Hi Mark,
I checked the last part of your previous response. I am too dumb to understand. Can that be used to INTERSECT existing Regions, but how...Sorry for bothering..
Mniaz
Message 9 of 10
sorry I can't help more. I have no idea what you're trying to do.
I only showed what looked like a problem in your code to add regions.
my post showed how to add a region for each circle.
If you have certain circles you want the "intersection region" for, put
those circles in the array and pass that to AddRegion.
Is that what you are trying to do?
maybe if you post an overview description of what your'e doing it would be
easier for someone to come up with a solution?
news:f19b1a9.6@WebX.maYIadrTaRb...
> Hi Mark,
I don't understand. Your previous post asked how to create regions from
circles. It didn't mention existing regions. I've never used regions so
don't know anything about them. Maybe someone else can understand better.
> Mniaz
Message 10 of 10
Hi Mark,
First of all thanks for bearing my questions. I am done with "Coverting circles into Regions." [[[[[[I am attaching a picture. Kindly look at it. This picture says, if user has some overlaping regions, he can get an intersection of those regions. I am trying to do the same but in VBA.
I think this explains the problem.]]]]]]]
Mniaz
