Convert Table/Schedule Object in an 2D Array
jtm2020hyo
jtm2020hyo
How could convert a Table/Schedule Object in an 2D Array?
I mean something like this:
ArrayVariable = {CellA1,CellB1,CellC1 ; CellA2,CellB2,CellC2 ; CellA3,CellB3,CellC3}
Accepted solutions (3)
grobnik
Hi @jtm2020hyo you can try with below procedure, could be not so quickly but it's working, let us know the result
Sub table_to_array()
Dim MyArr() As Variant
Dim MyObject As AcadObject
Dim MyTable As AcadTable
For Each MyObject In ThisDrawing.ModelSpace
    If TypeOf MyObject Is AcadTable Then
       Set MyTable = MyObject
        Tot_Row = MyTable.Rows
        Tot_Col = MyTable.Columns
        Exit For
Next
ReDim MyArr(Tot_Col, Tot_Row)
MyTable.RegenerateTableSuppressed = True
For TableRow = 1 To Tot_Row
    For TableCol = 1 To Tot_Col
        MyArr(TableCol, TableRow) = MyTable.GetCellValue(TableRow, TableCol)
    Next
Next
MyTable.RegenerateTableSuppressed = False
End Sub
grobnik
@jtm2020hyo pls check the code, I made a little modification on
and below setting to False.
jtm2020hyo
Your code work perfectly.
... Just curiously, is there any method to read Schedule Objects for AutoCAD MEP or Architecture?
grobnik
@jtm2020hyo I'm sorry I don't know in deep such product, you should try to find something on web or on line help related to vba development specific for that product. I guess yes but I don't know how.
grobnik
Hi @jtm2020hyo I found a post here concerning the schedule and MEP
https://forums.autodesk.com/t5/vba/managing-schedule-table/m-p/9786098
Try to read and in case apply.
