Convert multiple *.DWG files to one *.PDF File Using Visual Basic
I'm new to the AutoCad world but have been asked to take Multiple *.DWG files from a directory and covert them into one *.PDF file using Visual Basic.
(I was told the *.PDF had to be from ADOBE Pro to keep some of the features they need).  Has anyone ever done this and is there any example code that could help me.
Mark
Alfred.NESWADBA
Command _PUBLISH can do that, without any line of code 😉
Would not know which feature that should be, I would use an AutoCAD internal PDF driver (by default smaller file-size by higher quality).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
What is _PUBLISH.  Is it a part of Autocad or Visual basic?
Alfred.NESWADBA
>> What is _PUBLISH
>>>click<<<
- alfred -
Alfred NESWADBA
Okay thanks, these are Autocad users that asked me about this so I will see if they are aware it can be done through _PUBLISH, or see if there is another reason why they wanted me to do this though Visual Basic.
