Controling AutoCAD document from the VB MDI form menu
Please share your valuable time and knowledge....
Is there any way to open "ACAD document" as child form in VB MDI form? Actually I wanted to control AutoCAD document from the VB MDI form menu.
What kind of "control"?
Ed
Hi Ed Jobe
Just like our forms in vb which is under MDI means like child form.
In short I wanted to open whole AutoCAD as a form of my application which will be child form of my MDI form.
From the Department of Stupid Programming Tricks:
[MDIForm1 code]
Option Explicit
Private Declare Function SetParent Lib "user32" (ByVal hWndChild As Long, ByVal hWndNewParent As Long) As Long
Private m_hAcadParent As Long
Private m_acad As AutoCAD.AcadApplication
Private Sub MDIForm_Load()
Set m_acad = CreateObject("AutoCAD.Application")
m_hAcadParent = SetParent(m_acad.hWnd, Me.hWnd)
m_acad.Visible = True
End Sub
Private Sub MDIForm_Unload(Cancel As Integer)
m_acad.Visible = False
SetParent m_acad.hWnd, m_hAcadParent
m_acad.Quit
End Sub
hi fantum
LOT LOT LOT LOT LOT LOT's of thanks u solved my whole problem
Thank u very much
What I did was help you put an elephant in a closet. I don't expect anything good to come of it and you probably shouldn't either.
