Control Names (collection) & 2004 dwg ocx
------- 1 --------
I am trying to loop through all the controls in a frame and if they are not
lables then set some properties, but how do I test the control type ?
Dim oCrl As Control
For Each oCrl In frame1.Controls
If ocontrol <> ??label?? Then
oCtrl.xxx
Next
replace ??label?? with... ?
------- 2 --------
Is there somewhere I can get the ocx Drawing Preview control for acad 2004 ?
(I have seen the code on http://code.acadx.com reguarding this preview
through API calls rather then the control, but I prefer to have the control)
"Brian McCavour asked"
not
There's probably a better way, but a quick hack would be to use the 'Tag'
property of the label control - add something like 'Label', then look for it
in your loop.
Private Sub Command2_Click()
For Each Control In Form1.Controls
If UCase(Control.Tag) <> "LABEL" Then
MsgBox "Gotcha!"
Next
End Sub
As far as ?#2, I can't answer that one. I believe there used to be a
Thumbnail Viewer out there, but I don't know if 2004 has one.
Good Luck,
Scott
Ahh yes, such a simple yet effective work-around thanks !
I saw a preview ocx for acad 2000, but when I tried to use it all I got was
black box, so im thinking the new 2004 file format has changed that, was
hoping for a new control.
"LochDhu" wrote in message
news:5CE12CE3FBAABD77810E54E2958FF410@in.WebX.maYIadrTaRb...
> not
it
> in your loop.
> MsgBox "Gotcha!"
> End If
> Next
> End Sub
> Good Luck,
> Scott
Brian McCavour wrote:
> ------- 1 --------
> are not lables then set some properties, but how do I test the
> control type ?
If Not ocontrol TypeOf Is Label Then
Typo alert!
If Not TypeOf ocontrol Is Label
Perfect, thanks again !
"Frank Oquendo" wrote in message
news:4EEFD4E761FD11468C0492B8A1FC3C3A@in.WebX.maYIadrTaRb...
> Typo alert!
