Control Design Center?
Is it possible to control Design Center programatically so that blocks get
inserted according to a drawing scale? I'm guessing that you can not.
Are there alternatives to using image menus that people are using for block
management?
Ben Rand
Totally untested idea:
Use the EndCommand event and monitor for DROPGEOM, then grab
the last item in the current space. If it's an insert,
change the scale.
http://www.acadx.com
"Ben Rand" wrote in message
news:[email protected]...
that blocks get
you can not.
are using for block
> management?
> Thanks,
> Ben Rand
It worked(!) except I had to watch for the -INSERT command. Does that seem
strange?
THANKS!
Ben
"Frank Oquendo" wrote in message
> change the scale.
