Control Arrays
Control Arrays
Control Arrays
When you copy a control on a form in VB6 you get asked if you would like to
create a control array. This does not happen in VBA.
Is it possible to do this through code in VBA?
All Hints Appreciated
Marty
Marty had this to say
VBA does not support control arrays.
There are 10 kinds of people:
Those who understand binary and those who don't
http://www.acadx.com
with that said, you can accomplish some things with controls named
similarly. for example, I have a form with 11 option buttons, named Opt1
thru Opt11. upon pressing a button, the button_click event will loop through
all controls on form looking for name like "Opt*", then see which of them is
value = true. then the last one or two characters of the control is the
index for deciding what to do based on user's selection. definitely not as
clean as a control array, but accomplishes the same thing.
Kevin
Kevin Terry had this to say
> similarly.
Conversely, you could simply have all realted controls invoke a common
subroutine passing themselves or some other identifying characteristic.
..Something like a bunch of Command Buttons with tag values of 1, 2, 3...n.
Then for each button, you could call a routine:
MyRouytine(CommandButton.tag)
Michel.
"Frank Oquendo" a écrit dans le message news:
D5DE8E00AAA911068D9921DEA0BA6918@in.WebX.maYIadrTaRb...
> > similarly.
