Connect to AutoCAD 2004 with VB.net
I have probleme to take active AutoCAD 2004 application with
Dim acadApp as AutoCAD.Application = GetObject(,"AutoCAD.Application.16")
But if I use
Dim acadApp as AutoCAD.Application = CreateObject("AutoCAD.Application.16")
Is strart new AutoCAD 2004
Some body can help me !!!
On Windows XP PRO, AutoCAD 2004 and VB.net
> GetObject(,"AutoCAD.Application.16") But if I use
> CreateObject("AutoCAD.Application.16") Is strart new AutoCAD 2004
In C#, I use System.Runtime.InteropServices.GetActiveObject all the time
with no problem. I'm sure GetObject is the same call but just the same,
try taking the long route. Also, you might try dropping the ".16" when
using GetObject.
There are 10 kinds of people. Those who understand binary and those who
don't.
http://code.acadx.com
(Pull the pin to reply)
