common dxf group 410 to filter Blocks on the current Layout?
Message 1 of 9
Why does this not work?
I'm trying to filter all blocks within the active layout. as soon as i try
to use the common dxf group 410 to filter Blocks on the current Layout the
selectionset is empty.
Dim gpCode(1) As Integer
Dim dataValue(1) As Variant
gpCode(0) = 410 ' common group for Layout
gpCode(1) = 0
dataValue(0) = ThisDrawing.ActiveLayout.Name ' current Layout Name
dataValue(1) = "INSERT" ' value for Group 2
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
ssetObj.Select acSelectionSetAll, , , groupCode, dataCode
Geuko Rooseboom
Decoprojekt
+31-315-270 856
g.rooseboom@decoprojekt.nl
Replies (8)
Message 2 of 9
I think you need to enclose your two filter criteria in an "AND" structure like this.
dim fType(3) as Integer
dim fData(3) as Variant
fType(0) = -4
fData(0) = " fType(1) = 410
fData(1) = ThisDrawing.ActiveLayout.Name
fType(2) = 0
fData(2) = "INSERT"
fType(3) = -4
fData(3) = "AND>"
ssetObj.Select acSelectionSetAll, , , fType, fData
Incidentally, I don't follow why you are assigning your filter array to a second set of
variables (groupCode and dataCode).
Also, if you take a look on AcadX.com at Frank Oquendo's BuildFilter sub, I think you will
find that it makes creating selection set filters a lot easier. With BuildFilter, the
previous code could be abbreviated to the following.
dim fType() as Integer
dim fData() as Variant
BuildFilter fType, fData, -4, " "AND>"
Happy Hunting.
Chuck Gabriel
"Geuko#" wrote in message
news:3D6A4EC88E866A9C276F16640BBFCF6B@in.WebX.maYIadrTaRb...
> Hi,
> gpCode(1) = 0
> groupCode = gpCode
> Geuko Rooseboom
> Decoprojekt
> +31-315-270 856
Message 3 of 9
VBA will not filter on group code 410. Here's an alternative approach.
Pass it your selection set and the name of the layout from which you
want to select objects.
Public Sub FilterLayout(ss As AcadSelectionSet, layoutName As String)
Dim max As Long, objArray() As AcadEntity
max = -1
For i = 0 To ss.Count - 1
If
LCase(acadApp.ActiveDocument.ObjectIdToObject(ss.Item(i).OwnerID).Layo
ut.Name) _
<> LCase(layoutName) Then
max = max + 1
ReDim Preserve objArray(0 To max)
Set objArray(max) = ss.Item(i)
Next
ss.RemoveItems objArray
End Sub
http://www.acadx.com
Message 4 of 9
"Chuck Gabriel" wrote in message
news:EB28007372F1017067219B7D3B01A696@in.WebX.maYIadrTaRb...
like this.
> fType(0) = -4
> fData(0) = " > fType(1) = 410
> fType(2) = 0
> fData(2) = "INSERT"
> fType(3) = -4
> fData(3) = "AND>"
I tried that, but it seems the -4 groups are not really needed.
second set of
I copied the initial code from an online sample
I think you will
BuildFilter, the
> BuildFilter fType, fData, -4, " 0, "INSERT", -4,
> "AND>"
> Happy Hunting.
> Chuck Gabriel
> > Hi,
try
the
> > gpCode(1) = 0
> > groupCode = gpCode
> > Geuko Rooseboom
> > Decoprojekt
> > +31-315-270 856
Message 5 of 9
Thanks for your approuch, i tried looping through the selection set but i
could not find a way to get the layout property.
But the question that bothers me is why this is not possilble in VBA, is it
AutoCAD being inconsequent?
Geuko
"Frank Oquendo" wrote in message
news:9F26E82D19455F6F7EAF18857EA1C3F0@in.WebX.maYIadrTaRb...
> max = -1
> If
> ut.Name) _
> max = max + 1
> End If
> Next
> End Sub
Message 6 of 9
Hey Geuko,
I've been wrestling with the exact same problem all day today. Dxf group code
410. It works in lisp like, (ssget "X" '((0. "INSERT")(2 . "myblock")(410 .
"Layout1"))). I'm sure you've tried this. There is a vba function that passes
lisp to the acad command line. I'm going to try and pass the above lisp code
and then grab the "previous" selection set in VBA. Just an idea. I'll let you
know if it works.
Eric
> Geuko
> > max = -1
> > If
> > ut.Name) _
> > max = max + 1
> > End If
> > Next
> > End Sub
Message 7 of 9
Geuko,
Frank Oquendo's code works. I tried it my self and it solved my problem.
This line of his code grabs the layout name of the entity passed to
it:
ThisDrawing.ObjectIdToObject(MY_ACAD_ENTITY.OwnerID).Layout.Name
Sincerely,
Eric
i try
the
    gpCode(1) = 0
Layout Name
    groupCode = gpCode
dataCode
Geuko Rooseboom
Decoprojekt
+31-315-270 856
Message 8 of 9
This code is OK.
1.- Open "SeleccionFiltrosLayout.dwg"
2.- Alt+F11 for IDE VBA
3.- Import Module "SelLayoutObject.bas"
4.- Run Sub "ListaObjetosLayouts"
** Attach Files of sample in "SeleccionFiltro.rar"
The CODE:
Public Sub ListaObjetosLayouts()
Dim cadena As String
Dim oL As AcadLayout
For Each oL In ThisDrawing.Layouts
cadena = cadena & DameObjetosLayout(oL.Name)
Next
MsgBox cadena
End Sub
Public Function DameObjetosLayout(queL As String) As String
Dim resultado As String
'' Definir "ssel" como el objeto selección y crearlo. Si ya existe
'' error y lo cojetos de la colección 'SelectionSets'
Dim ssel As AcadSelectionSet
On Error Resume Next
Set ssel = ThisDrawing.SelectionSets.Add("alberto")
If Err.Number <> 0 Then
Set ssel = ThisDrawing.SelectionSets.Item("alberto")
'' Lo vaciamos, por si ya tenía objetos
ssel.Clear
'' Definir las variables para el código y valor del filtro
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
gpCode(0) = 410
dataValue(0) = queL
'' Pasamos estos objetos a otros 'Variant'
groupCode = gpCode
ssel.Select acSelectionSetAll, , , groupCode, dataCode
resultado = "Hay ( " & ssel.Count & " ) Objetos seleccionados en Layout ( " & queL & " )" & vbCrLf
ssel.Clear
Set ssel = Nothing
DameObjetosLayout = resultado
End Function
Message 9 of 9
Thats a known limitation of vba
you cant' use the 410 code in filter list (like you can in lisp)
google the archives for confirmation of this and previous discussions
you have to filter for your object then test it's layout owner
or to get the result in your code sample you would do
resultado = "Hay ( " & Layouts.Item("quel").Block.Count & " ) Objetos en
hth
mark
wrote in message news:6212391@discussion.autodesk.com...
This code is OK.
The CODE:
Next
MsgBox cadena
End Sub
ssel.Clear
gpCode(0) = 410
dataValue(0) = queL
groupCode = gpCode
ssel.Clear
Set ssel = Nothing
End Function
