COMBOBOX reaction
COMBOBOX reaction
Jedimaster
COMBOBOX reaction
Jedimaster
I have a VBA routine with a userform that has a combobox in it.
I did not know which to use
The default seems to be
Private Sub ComboBox1_Change
But I also thought about
Private Sub ComboBox1_Click
With that said I, am trying to  to get the routine to only react when the ComboBox is used. However, the seem to invoke on initialization of the form instead of when the combobox is being used.
Hallex
Use change event but after initializinf the form
set index to -1:
{code}
Private Sub UserForm_initialize()
' fill combo with your values:
Dim i
For i = 1 To 10
ComboBox1.AddItem i
Next
ComboBox1.ListIndex = -1
End Sub
Private Sub ComboBox1_Change()
If ComboBox1.ListIndex <> -1 Then
MsgBox ComboBox1.Text
End Sub
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Jedimaster
Works good... The only thing is now you lose th ability to set a default.
