Click event runs when initializing a check box?
mdhutchinson
Advisor Advisor
mdhutchinson
I have an event procedure for my check box intended to be ran if the user clicks the control… but for some reason the event procedure is running when I put a check mark in the control … even before the form gets to the screen. Below are the three procedures.
Public Sub Main()
‘ this code runs first…
‘ do some stuff
UserForm1.Show ‘ fires UserForm_Initialize event
End Sub
Private Sub UserForm_Initialize()
‘ do some stuff here
‘ then initialize my check box…
initMyCheckBox ‘ run sub procedure to initialize check box
End Sub
Private Sub initMyCheckBox ()
' check & set status
‘ if condition is true then set the value of the check box to True
If condition Then
MyCheckBox.Value = True ‘ << runs MyCheckBox _Click event… WHY???
MyCheckBox.Enabled = False
End Sub
Private Sub MyCheckBox _Click()
‘ If user clicks to place a check in the check box then…
‘ ….. do some stuff
‘ else
‘ ….. do some other stuff.
If MyCheckBox.Value = True Then
‘do some stuff
Else
‘do some other stuff
End Sub
I think what you're looking for is under:
MyCheckBox _Change
(not) MyCheckBox _Click
mdhutchinson
Well I thought ... THAT'S IT... but no...
I edited my event procedure to be MyCheckBox _Change
instead of MyCheckBox _Click...
Now the Change event is running...
All I want to do is intialize the form with a check in the box based on a condition being true... If the condition is true then I want the dialog presented to the user with a check in the control. But the click event code intended for the user click runs mistakenly ...
Yes, Check_Box_Click/CheckBox_Change event fires when you programmatcially
set Check Box's value.
So, if you want to avoid code in the event handler procedure running in
UserForm_Initialize(), where you set CheckBox's value, you could declear a
flag in UserForm module level. Like this:
Private mInitialize as Boolean
Private Sub UserForm_Initial()
'Set flag to false
mInitialize=False
'...Do initializing, including set CheckBox's value
'After all initialzation done, set flag to true
mInitialize=True
End Sub
Private Sub CheckBox1.Change()
''If the event is fired during initialization, exit immediately
If Not mInitialize Then Exit Sub
''Following code executed when event fired due to user action
End Sub
wrote in message news:5451981@discussion.autodesk.com...
clicks the control. but for some reason the event procedure is running when
I put a check mark in the control . even before the form gets to the screen.
Public Sub Main()
' this code runs first.
' do some stuff
UserForm1.Show ' fires UserForm_Initialize event
End Sub
' do some stuff here
' then initialize my check box.
initMyCheckBox ' run sub procedure to initialize check box
End Sub
' if condition is true then set the value of the check box to True
If condition Then
MyCheckBox.Value = True ' << runs MyCheckBox _Click event. WHY???
End Sub
' If user clicks to place a check in the check box then.
' ... do some stuff
' else
' ... do some other stuff.
'do some stuff
Else
'do some other stuff
End Sub
mdhutchinson
Thanks... that worked...
This same variable should work for any other initializing that I need when it triggers other events.
What I did in my form module
Option Explicit
Private initializing As Boolean
initializing = True
'... any other initializing code
initializing = False
End Sub
If condition Then
End Sub
If initializing Then Exit Sub ' exit the sub if initializing
‘do some stuff
Else
End Sub
