CLEAN COMMAND INTERFACE FROM VBA
IS THERE A WAY TO CLEAN TE COMMAND INTERFACE (YOU KNOW WHERE TYPES THE COMMAND) FROM VBA?
Are you wanting to clean just the current line, or the whole history since they started editing the dwg? -- ---- Ed ---- "diAb0Lo" wrote in message news:17519529.1089093540526.JavaMail.jive@jiveforum2.autodesk.com... IS THERE A WAY TO CLEAN TE COMMAND INTERFACE (YOU KNOW WHERE TYPES THE COMMAND) FROM VBA?
send me both ways... I will be glad to you
These two posts are in answer to "Clean command interface from VBA" but attached to a different thread. Copying them here for clarity. -- --- Anne Brown Discussion Groups Administrator Autodesk, Inc. ================= Subject: Re: System variables - VBA Date: Tue, 6 Jul 2004 10:31:44 -0700 From: "Ed Jobe" Newsgroups: autodesk.autocad.customization.vba  Starting with 2000, you can't control the contents of the text window. It saves the last 400 lines. You can only control whether the content is saved to a *.log file. You can clean the current prompt by sending another promt line to the command line, thus forcing the one you don't like further back in the command history. Here's a function I wrote to handle sending prompts Sub CommandLine(msg As String) ThisDrawing.Utility.Prompt (msg & vbCrLf & "Command: ") End Sub To clear the last prompt, use: CommandLine "" *** Subject: Re: System variables - VBA Date: Tue, 6 Jul 2004 13:14:56 -0500 From: "MP" Newsgroups: autodesk.autocad.customization.vba  what about (defun CmdHistLines( / numlines i) (setq numlines(Getint"\nNumber of lines")) (setq i 0) (setenv"CmdHistLines"(itoa numlines)) ;to test (repeat(atoi(Getenv"CmdHistLines")) (print(setq i(1+ i)))) ) 4000 used to be the upper limit now(a2k5) 2048 seems to be the max "Ed Jobe" wrote in message news:40eae200$1_1@newsprd01... Starting with 2000, you can't control (snip) diAb0Lo wrote: > > send me both ways... I will be glad to you
Hi, Try this. I use variations of it in all the Menufile.MNL files I create and call it from all functions. (defun CADAppsCleanCommandLine (spFunctionString) (setq n (strlen spFunctionString)) (repeat n (princ (chr 8))) (repeat n (princ (chr 32))) (princ) ) Typical function: (defun C:SelectRoad () (setq pbProgName (strcat spbARDRoadProgram "SelectRoad")) (vl-vbarun pbProgName) (CADAppsCleanCommandLine pbProgName) ) ; end Defun SelectRoad -- Laurie Comerford CADApps www.cadapps.com.au "Anne Brown" wrote in message news:40EB046C.CFD2BBDA@autodesk.com... > These two posts are in answer to "Clean command interface from > VBA" but attached to a different thread. Copying them here for > clarity. > -- > --- > Anne Brown > Discussion Groups Administrator > Autodesk, Inc. > > ================= > > Subject: > Re: System variables - VBA > Date: > Tue, 6 Jul 2004 10:31:44 -0700 > From: > "Ed Jobe" > Newsgroups: > autodesk.autocad.customization.vba > > >  > Starting with 2000, you can't control the contents of the text > window. It saves the last 400 lines. You can only control whether > the content > is saved to a *.log file. You can clean the current prompt by > sending another promt line to the command line, thus forcing the > one you > don't like further back in the command history. Here's a function > I wrote to handle sending prompts > > Sub CommandLine(msg As String) > ThisDrawing.Utility.Prompt (msg & vbCrLf & "Command: ") > End Sub > > To clear the last prompt, use: > CommandLine "" > > *** > Subject: > Re: System variables - VBA > Date: > Tue, 6 Jul 2004 13:14:56 -0500 > From: > "MP" > Newsgroups: > autodesk.autocad.customization.vba > >  > what about > (defun CmdHistLines( / numlines i) > (setq numlines(Getint"\nNumber of lines")) > (setq i 0) > (setenv"CmdHistLines"(itoa numlines)) > > ;to test > (repeat(atoi(Getenv"CmdHistLines")) > (print(setq i(1+ i)))) > ) > 4000 used to be the upper limit > now(a2k5) 2048 seems to be the max > > "Ed Jobe" wrote in message > news:40eae200$1_1@newsprd01... > Starting with 2000, you can't control (snip) > > diAb0Lo wrote: > > > > send me both ways... I will be glad to you
