checking selection set for similar items
Hoping some one can give me some insight into how to do this in vb. I'm a
relatively new vb programmer.
I have a selection set of mtext objects. The text string of these objects
is in the following format: (4-EACH) MAPLE TREE
I'm doing a BOM takeoff for all of these labels and what I need to do is
combine the labels of similar items together so that I have a grand total of
each item in the drawing in my output file. For clarification: I have the
following labels in my drawing (4-EACH) MAPLE TREE, (2-EACH) MAPLE TREE,
(9-EACH) MAPLE TREE. In my output file, I don't want to have three separate
lines for the maple tree I only want one: 15 Maple Trees. How can I loop
through the selection set to determine if I have more than one type of item
in the set. I'll have to do some type of string parsing to retrieve the
number and the actual item.
Ryan
Dear Ryan,
Hmm, something like;
Dim Total as Long
for each mtext in Selectionset
if mtext.text like "MAPLE TREE" then
Total=Total + Clng(mid(mtext.text,2,1)
end if
next mtext
For you to find the rough edges.
wkr, jwk
(Frank will now moan about this did-your-homework-answer polluting the ng 🙂
Ryan Small had the next bright idea:
> Thanks,
> Ryan
You ask a silly question, you get a technical answer...
The like operator,,,,, wow!,,,,, I see you did your homework 🙂 Definitely not
criticizing, I had to look it up, but shouldn't it be "* MAPLE TREE" and what
happens if there are (10 each)? Oh, never mind, LEN is a rough edge 🙂
-Josh
jwk wrote:
> Dear Ryan,
> Dim Total as Long
> end if
> next mtext
> wkr, jwk
> > Thanks,
> > Ryan
There's only one word for this, and that's "blurk".... that's the sound my
mind makes when i see a question like this. Roughly translated; "hmmm that
shouldn't be that hard to solve. If i had to code this, i would do SOMETHING
like this." I'm only posting this
blurk also in a follow up in the hope that bringing confusion will stimulate
the questionmaker in more intensive thinking which will bring him (or her)
closer to the blessing of solving the problem... And of course for you to
respond 🙂
wkr, jwk
Minkwitz Design had the next bright idea:
>not criticizing, I had to look it up, but shouldn't it be "* MAPLE TREE"
>and what happens if there are (10 each)? Oh, never mind, LEN is a rough
>edge 🙂 -Josh
>jwk wrote:
>> Dear Ryan,
>> Dim Total as Long
>> end if
>> next mtext
>> wkr, jwk
>> ng 🙂
I had a look through a pile of papers that contains the vb statements and
functions and never saw anything about the LIKE operator. Following your
reply, I went back through this paper collection to see if I had missed it
when I checked the first time, but it wasn't there. I then attempted some
type of string parsing but realized there had to be a better way via a
function similar to (vl-string-search) in lisp.
Ryan
"jwk" wrote in message
news:Xns9050BB8E4aoposhotmailcom@64.124.46.110...
SOMETHING
this
stimulate
> respond 🙂
Dear Ryan,
I was stunned when i read your reply because i use the Like operator almost
daily! And still i started up Acad VBA IDE to check if i wasn't going
insane. Choosing help, typing Like in the index, and there it was. So, i
think there's maybe one sheet missing in your pile of paper 🙂 Just try
it. And as some "designer":-) correctly stated, you have to use a wildcard.
Try:
msgbox "a t in theepot is " & ("theepot" like "t*")
wkr, jwk
> and
> Ryan
Checked the page numbers, all there! Time for some new documentation.
Ryan
news:Xns9051D7D42aoposhotmailcom@64.124.46.110...
> Dear Ryan,
> So, i think there's maybe one sheet missing in your pile of paper 🙂 Just
try
> it.
