Checking if something exists in a collection
What am I doing wrong here?
How do I check to see if an item exists in collection?  This bombs
out at the red line.
Sub Test()
    Dim acdTxtStylesColl As AcadTextStyles
    Dim strTxtStyleName As String
    strTxtStyleName = "ISO3098B"
    Set acdTxtStylesColl = ThisDrawing.TextStyles
    If acdTxtStylesColl.Item("strTxtStyleName")
Then
        MsgBox "STYLE EXISTS"
End Sub
NOTICE: This message contains privileged and confidential information
intended only for the use of the addressee named above. If you are
not
the intended recipient of this message you are hereby notified that
you
must not disseminate, copy or take any action in reliance on it. If
you
have received this message in error please notify Sinclair Knight Merz
Pty Ltd immediately. Any views expressed in this message are those
of
the individual sender, except where the sender has the authority to
issue and specifically states them to be the views of Sinclair Knight
Merz.
CAUTIONARY NOTES CONCERNING THE USE OF ELECTRONICALLY TRANSFERRED DATA
SINCLAIR KNIGHT MERZ
The documentation produced by using this electronic data is uncontrolled
and not subject to
update. The recipient is responsible for reviewing the status of the
transferred information and
should advise Sinclair Knight Merz immediately upon receipt of any
discrepancy. The design
and details are applicable to the intended project only and must not
be
reproduced wholly or
in part, or supplied to any third party without the written permission
of Sinclair Knight Merz
who retains copyright of all the transmitted material
The sender makes no warranty regarding the presence of electronic or
magnetic data errors
or computer viruses, or as to the accuracy or completeness of the data
transmitted.
Four words: On Error Resume Next
BTW, that is one obnoxious signature you have there not to metnion
rather non-sensical given the fact that you posted a question to no
specific person in a public forum.
http://www.acadx.com
Win a free autographed copy of
"AutoCAD 2000 VBA Programmer's Reference"
by Joe Sutphin
"Viney, Scott" wrote in message
news:3AA81F0D.ADF2FFCA@skm.com.au...
How do I check to see if an item exists in collection? This bombs out
at the red line.
Sub Test()
If acdTxtStylesColl.Item("strTxtStyleName") Then
End Sub
Frank,
Sorry about the work blurb. But can you explain how to the On Error
Resume Next will work? I jsut want to test if an object exists within a
collection.
Cheers mate
Scott V
> by Joe Sutphin
> at the red line.
> Sub Test()
> End If
> End Sub
Hi Scott,
Something along this line..
Public Function DoesStyleExist(strTxtStyleName As String) As Boolean
Dim acdTxtStyle As AcadTextStyle
Set acdTxtStyle = acdTxtStylesColl.Item(strTxtStyleName)
DoesStyleExist = (Err.Number = 0)
Err.Clear
End Function
Randall Rath
Drop the inverted commas inside the bracket. As it stands it is looking for an item called strTxtStyleName rather than the string that the variable strTxtStyleName refers tp
You should try somthing like this
> > Sub Test()
Dim acdTxtStyle as AcadTextStyle
On Error GoTo EssSt
Set acdTxtStyle= acdTxtStylesColl.Item("strTxtStyleName")
On Error Goto 0
Exit Sub
SomeThing:
Ext Sub
EssSt: MsgBox "It does not extist"
Resume Something
End Sub
