Message 1 of 1
Checking if Hatch is empty?
05:40 AM
I am working on a code which checks if a prescribed polyline is empty and if it is empty then enter a block.
The insertion is working but the code is inserting the block even if the block already exists. how do i fix this?
Dim aBlock As AcadBlock
Dim aBlockRef As AutoCAD.AcadBlockReference
Dim aent As AutoCAD.AcadEntity
Dim elem As Object
Dim arr As Variant
Dim BBminPoint(0 To 2) As Double
Dim BBmaxPoint(0 To 2) As Double
Dim Ipoint(0 To 2) As Double
Dim IPointArea(0 To 2) As Double
Dim IPointDesig(0 To 2) As Double
Dim strIPoint As String
Dim strBBMin As String
Dim strBBMax As String
Dim Floor_No As String
Dim insertionPoint(2) As Double
Dim minExt As Double, maxExt As Double
Dim folderPath As String
Dim plPointLL, plPointUR As Variant
Dim pWidth, pHeight As Double
Dim bWidth, bHeight As Double
Dim scaleFactor As Double
Dim fPath As String
Dim fileName As String
'Dim objBlockRef As AcadBlockReference
Dim scale1(2) As Integer
Dim XLL(2), YLL(2), XUR(2), YUR(2) As Double
Dim blockName As String
Public Sub AddSpaceBlock() Dim acUtil As AcadUtility Dim acVport As AcadViewport Dim acSS As AcadSelectionSet Dim acVp As AcadObject Dim sLayout As String Dim iCode() As Integer Dim vValue() As Variant Dim vPt As Variant Dim vPtMs As Variant Dim dHt As Double Dim dWd As Double Dim dScl As Double Dim dUR(2) As Double Dim dLL(2) As Double Dim vBlnInfo As Variant Dim blk As AcadBlockReference Dim elem As AcadEntity Dim blkLL As Variant Dim blkUR As Variant Dim objBlockRef As AcadEntity Set acUtil = ThisDrawing.Utility 'Dim pli As AcadPolyline Dim blnBlkFound As Boolean Dim intersectP() As Double Dim bblk As AcadBlock Dim count As Integer Dim textString As String Dim rsSpace As ADODB.Recordset Dim pline As AcadLWPolyline Dim SSet As AcadSelectionSet Dim filttype(1) As Integer ReDim filtdata(1) As Variant Dim dxfCode, dxfValue Dim nestEnt(0) As AcadEntity Dim oBlkRef As AcadBlockReference Dim hatchobj As AcadHatch filttype(0) = 0 filttype(1) = 2 filtdata(0) = "INSERT" filtdata(1) = "Etichetta Locale" dxfCode = filttype: dxfValue = filtdata fPath = "C:\Users\VEANKA LT002\Documents\ACAD\Blocks\" fileName = fPath + "Space_Info.dwg" dblX = 1 dblY = 1 dblZ = 1 dblRotation = 0 Set rsSpace = New ADODB.Recordset rsSpace.CursorLocation = adUseClient rsSpace.Fields.Append "ObjectID", adBigInt rsSpace.Open Dim rsNIA As ADODB.Recordset Set rsNIA = New ADODB.Recordset rsNIA.CursorLocation = adUseClient rsNIA.Fields.Append "LAYER", adVarChar, 50 rsNIA.Fields.Append "BLOCK", adVarChar, 30 rsNIA.Fields.Append "FLOOR", adVarChar, 30 rsNIA.Fields.Append "AREA", adDouble rsNIA.Fields.Append "XLL", adDouble rsNIA.Fields.Append "XUR", adDouble rsNIA.Fields.Append "YLL", adDouble rsNIA.Fields.Append "YUR", adDouble rsNIA.Fields.Append "check", adChar, 1 rsNIA.Open 'GET blocks with ObjectIDs For Each elem In ThisDrawing.ModelSpace If elem.EntityName = "AcDbBlockReference" Then Set blk = elem If UCase(blk.Name) = "SPACE_INFO" Then rsSpace.AddNew rsSpace.Fields(0).Value = blk.ObjectID rsSpace.Update End If End If Next rsSpace.MoveFirst 'now check if the blocks exist in the policy For Each elem In ThisDrawing.ModelSpace If elem.EntityName = "AcDbPolyline" Then elemLayer = elem.Layer Set pline = elem If InStr(1, elemLayer, "F07200") > 0 Then blockName = Right(elemLayer, 2) If Left(blockName, 1) = "0" Then blockName = Right(blockName, 1) End If If Not IsNumeric(Mid(elemLayer, 7, 1)) Then 'And (elem.LinetypeScale = 3 Or elem.LinetypeScale = 2) Then ' This is NIA layer PatternName = "ANSI31" PatternType = 0 bAssociativity = True blnBlkFound = False ' Create the associative Hatch object Set nestEnt(0) = pline Set hatchobj = ThisDrawing.ModelSpace.AddHatch(PatternType, PatternName, bAssociativity) hatchobj.AppendInnerLoop (nestEnt) ' hatchobj.Evaluate hatchobj.IntersectWith blk, acExtendNone rsSpace.MoveFirst Do While Not rsSpace.EOF Set blk = ThisDrawing.ObjectIdToObject(rsSpace.Fields(0).Value) intersectP = pline.IntersectWith(blk, acExtendNone) If UBound(intersectP) > -1 Then blnBlkFound = True Exit Do Else blnBlkFound = False End If rsSpace.MoveNext Loop hatchobj.Delete If blnBlkFound = False Then ThisDrawing.Regen acActiveViewport rsNIA.AddNew rsNIA.Fields("LAYER").Value = elemLayer rsNIA.Fields("BLOCK").Value = blockName rsNIA.Fields("FLOOR").Value = Mid(elemLayer, 7, 2) G_Area = Round((pline.Area / 1000000), 4) rsNIA.Fields("AREA").Value = G_Area elem.GetBoundingBox plPointLL, plPointUR rsNIA.Fields("XLL").Value = plPointLL(0) rsNIA.Fields("YLL").Value = plPointLL(1) rsNIA.Fields("XUR").Value = plPointUR(0) rsNIA.Fields("YUR").Value = plPointUR(1) rsNIA.Update 'now create and insert a new block bWidth = 30 bHeight = 5 pWidth = rsNIA.Fields("XUR").Value - rsNIA.Fields("XLL").Value pHeight = rsNIA.Fields("YUR").Value - rsNIA.Fields("YLL").Value If pWidth < pHeight Then scale1(0) = (pWidth * 0.25 / bWidth) '* 100 scale1(1) = scale1(0) scale1(2) = scale1(0) Else 'scenario 2 scale1(1) = (pHeight * 0.25 / bHeight) '* 100 scale1(0) = scale1(1) scale1(2) = scale1(1) End If insertionPoint(0) = rsNIA.Fields("XLL").Value + (pWidth / 2) '- ((bWidth * scale1(0)) / 8) insertionPoint(1) = rsNIA.Fields("YLL").Value + (pHeight / 2) '- ((bHeight * scale1(1)) / 8) insertionPoint(2) = 0 Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(insertionPoint, fileName, scale1(0), scale1(1), scale1(2), 0) ThisDrawing.Regen acAllViewports End If End If End If End If Next End Sub
What changes need to be done to make this code work?
