Check if VBA Project is loaded...
Is there any way to check (in AutoLISP)
what (if any) VBA project is loaded?
Basically I'm using AutoLISP to initialize
my VBA App. and it works fine
in AutoCAD 2000i with
(command "-vbarun" path!project.module.macro)
however in AutoCAD R14 (& 14.01)
which are also being used to run the App.
cannot use this syntax. it can only use
module.macro
It's great in AutoCAD 2000i because the
command loads and runs the App.
but in AutoCAD 14 (& 14.01) you have to load
the project first...
How do I check to see if the project is already loaded?
(In AutoLISP)
TIA
Thomas Smith
Put this function in a VB ActiveX DLL and you can call it from VL.
Public Function GetVBAProjects() As Variant
Dim i As Long, projects() As String
Dim objIDE As VBIDE.vbe
Set objIDE = Application.vbe
ReDim projects(0 To objIDE.VBProjects.Count - 1, 1)
For i = 0 To objIDE.VBProjects.Count - 1
projects(i, 0) = objIDE.VBProjects(i + 1).Name
projects(i, 1) = objIDE.VBProjects(i + 1).BuildFileName
Next
GetVBAProjects = projects
End Function
Joe
"Thomas Smith" wrote in message
news:30A1BEB71C948CBF94613EE9E8DB24A3@in.WebX.maYIadrTaRb...
> module.macro
> (In AutoLISP)
> TIA
> Thomas Smith
Correct me if I'm wrong, but don't you have to have
Visal Lisp installed to use any of the VL functions?
I'll be using this App. in R14 & R14.01
Niether of which have VL included...
How do I get around this?
And wouldn't that function only work for Acad 2000?
From what I understand, Acad R14 cannot have multiple
projects loaded?
"Joe Sutphin" wrote in message
news:A84D3968D4D285DC4F5328F270112F24@in.WebX.maYIadrTaRb...
> Next
> End Function
> Joe
> > module.macro
> > (In AutoLISP)
> > TIA
> > Thomas Smith
