Check Boxes
Check Boxes
Check Boxes
Could someone give me some advice on the proper programming
to treat check boxes as toggles.
I have setup a form that will allow users to setup layer names from our standards through the use of check boxes. However, the way that I have it programmed now the layer name is added immediately. I would like to be able to allow the user to select as many or as few layers as they want then compile the layers upon them exiting the form.
When the user presses OK or whatever, you can test all of the check boxes Checked property to see if they are checked or not.
