Changing Block Attributes
I have 500+ drawings that I have to change two (2) to four (4) of the Title
Block attributes. So far I have been able to come up with the following
code (with the help of this newsgroup):
Public Sub T_TBChange()
Dim AttArray As Variant
Dim Obj As Object
Dim blkRef As AcadBlockReference
Dim BlockName As String
Dim returnString As String
Dim TPn As String
Dim TDes As String
Dim objWorksheet As Object
Dim objWorkBook As Object
If blnAll = False Then
For Each Obj In ThisDrawing.PaperSpace
If TypeOf Obj Is AcadBlockReference Then
Set blkRef = Obj
If blkRef.HasAttributes Then
AttArray = blkRef.GetAttributes
For I = LBound(AttArray) To UBound(AttArray)
' MsgBox AttArray(i).TagString
MsgBox returnString
If AttArray(I).TagString = "PB2" Then
AttArray(I).TextString = TPn
in VBA.
If AttArray(I).TagString = "A" Then
AttArray(I).TextString = TDes
Next I
Next
End Sub
The problem that I am having the attribute TextString is going to be
changing in each drawing (along with the other two attributes, that I have
not yet defined in this code).
I need to be able to input these new TextString values (TPn and TDes) from
a input routine when the code runs.
For some reason - I have not been able to do this with my limited knowledge
in VBA.
Thanks in advance Robert Funk
Inline comments:
"Robert Funk" wrote in message
news:8D87882645738E7DB129F70E5FBEAFD4@in.WebX.maYIadrTaRb...
Title
'####################### Following line changed
> Public Sub T_TBChange(TPn as string, TDes as string, NewVal1 as string,
NewVal2 as string)
> Dim Obj As Object
'#################### the following two lines commented out
'Dim TPn As String
'Dim TDes As String
> Set blkRef = Obj
> MsgBox returnString
'###################### Following line added
if AttArray(i).TagString = "Target1" then
AttArray(i).TextString = NewVal1
if AttArray(i).TagString = "Target2" then
AttArray(i).TextString = NewVal2
> in VBA.
> Next I
> End If
> End If
> Next
> End If
> End Sub
You might also want to consider using Select Case:
Set AttObj = AttArray(i)
Select Case AttObj.TagString
Case is = "Target1"
AttObj.TextString = NewVal1
Case is = "Target2"
AttObj.TextString = NewVal2
Case is = "PB2"
AttObj.TextString = TPn
Case is = "A"
AttObj.TextString = TDes
End Select
Next I
snip...
Mike Weaver
It seem that I am having trouble with my email at home so I will repost to the newsgroupe and you.
The ones that I will be doing will have one block to each layout and only
one of these blocks in the drawing, in the paper space layout.  The code
runs as expected when I have a string valve  "10004567" substituted for the
value of  TPn  and  an value of "B" in the for the second attribute (TDes
value) in the following lines:
   If AttArray(I).TagString = "PB2" Then AttArray(I).TextString = TPn
   If AttArray(I).TagString = "A" Then AttArray(I).TextString = TDes
I have tried to enter the text in a listbox by typing this as a number
(string value without the quotes) and then having the out put of the listbox set to a string value/s
to the variable/s of TPn and TDes in a second listbox.
---- Original Message -----
To: "Robert Funk" <bob_funk@prodigy.net>
Sent: Tuesday, May 29, 2001 10:42 AM
Subject: Re: Changing Block Attributes
> Robert,
> How many title block in a drawing, one for each drawing or ....
> Bernard
> ----- Original Message -----
> From: Robert Funk <bob_funk@prodigy.net>
> To: Bernard Flavignard <be.flavi@infonie.fr>
> Cc: Robert Funk <bob_funk@cooksonpm.com>
> Sent: Tuesday, May 29, 2001 7:23 PM
> > 95% of all the title blocks are the same.  The two attributes tags (PB2
> A)
> > are all the same in most of the blocks.  The current strings have
> different
> > information attached to the blocks.  The new information to be written
> into
> > the blocks will be different in each block.  I hop to put this in as the
> > code is running for each block.
> > Drawing Attached.  Drawing format AutoCad MDT5 Service Pack 3.
> >         Thanks for ypu response and HELP.
> > From: "Bernard Flavignard" <be.flavi@infonie.fr>
> > Sent: Tuesday, May 29, 2001 6:42 AM
> > > Robert,
> > > Do you want the same new string for each block with tagstring = "PB2"
> > > Or do you want differents news strings
> > > Can you send me one of your drawing with your blocks
> > > Bernard
> > > Newsgroups: autodesk.autocad.customization.vba
> > > Sent: Tuesday, May 29, 2001 2:20 PM
> > > Subject: Changing Block Attributes
the
> > > Title
> following
> > > > Dim Obj As Object
> > > > Dim TPn As String
> > > > Dim TDes As String
> > > >         Set blkRef = Obj
> > > >                 MsgBox returnString
> > > >                      in VBA.
> > > >                 Next I
> > > >             End If
> > > >         End If
> > > >     Next
> > > > End If
> > > > End Sub
I
> > have
TDes)
> > > from
> > > knowledge
> > > > in VBA.
Mike Weaver wrote:
Inline comments:
"Robert Funk" <bob_funk@prodigy.net> wrote in message
Title
NewVal2 as string)
Dim Obj As Object
'Dim TPn As String
'Dim TDes As String
Set blkRef = Obj
MsgBox returnString
in VBA.
Next I
Next
End Sub
Case is = "Target1"
Case is = "Target2"
Case is = "PB2"
Case is = "A"
End Select
Next I
snip...
Mike Weaver
I am having trouble with my home email, so I did
not receive your response till today, when I came back to work. Thanks for
your help.  This is and the additional help I received will make changing
all the drawing title blocks an easier job.
One other question - Since I also have the part number (eight digit number
as 10004545) in the BOM block (for AutoCad Mechanical Desktop MDT5 w/service
pack 3) is their an easy way to automatically put this in the BOM and Part
list in the layout.  Most of the drawings will consist of only one model
(made up of only one part) and only one layout in the drawing.
I will be inserting an new part list format into each drawing, so I thought
while I am inserting it, there would be a way of getting some of the information
that I would be imputing for the title block.
           T H A N K S   In Advance.
Mike Weaver wrote:
Inline comments:
Title
NewVal2 as string)
Dim Obj As Object
'Dim TPn As String
'Dim TDes As String
Set blkRef = Obj
MsgBox returnString
in VBA.
Next I
Next
End Sub
Case is = "Target1"
Case is = "Target2"
Case is = "PB2"
Case is = "A"
End Select
Next I
snip...
Mike Weaver
Bob,
I don't know very much about MDT, but if the bom is
a block with attributes you should be able to modify these attributes the same
way you would with the titble block.
Mike
I
am having trouble with my home email, so I did not receive your response till
today, when I came back to work. Thanks for your help.  This is and the
additional help I received will make changing all the drawing title blocks an
easier job.
(eight digit number as 10004545) in the BOM block (for AutoCad Mechanical
Desktop MDT5 w/service pack 3) is their an easy way to automatically put this
in the BOM and Part list in the layout.  Most of the drawings will
consist of only one model (made up of only one part) and only one layout in
the drawing.
so I thought while I am inserting it, there would be a way of getting some of
the information that I would be imputing for the title
block.
           T H A N K S
  In Advance.
@mike Weaver wrote:
type="cite">
Inline comments:
Title
NewVal2 as string)
Dim Obj As Object
'Dim TPn As String
'Dim TDes As String
Set blkRef = Obj
MsgBox returnString
in VBA.
Next I
Next
End Sub
Case is = "Target1"
Case is = "Target2"
Case is = "PB2"
Case is = "A"
End Select
Next I
snip...
Mike Weaver
